Difference between LS1 and "generic" cam degree kit?
Old Jun 28, 2013 | 06:13 PM
showvette's Avatar
Default Difference between LS1 and "generic" cam degree kit?
I see cam degree sets listed for LS1 engines. What is the difference between these and a typical SBC degree kit? Can I use a regular SBC kit on an LS1?
Frank
Old Jun 29, 2013 | 07:00 AM
RezinTexas's Avatar
post a link of the SBC kit
Old Jun 29, 2013 | 07:32 AM
Darkman's Avatar
https://ls1tech.com/forums/generatio...mendation.html
Old Jun 29, 2013 | 10:17 AM
RezinTexas's Avatar
is your engine in our out of the car? Heads on or off?
I got all my tools for this on Jegs. 2x dial indicators, magnetic boom stand, bridge stand, 9" wheel, etc.
Old Jun 29, 2013 | 11:10 AM
JakeFusion's Avatar
Super Hulk Smash
If it's in the car, it's a bit more of a pain.
Rezin, did you get the Jegs kit or just buy each individually?
Old Jun 29, 2013 | 11:34 AM
showvette's Avatar
Engine is out of car.
Old Jun 29, 2013 | 03:10 PM
RezinTexas's Avatar
I bought the pieces individually. I did the cam with the heads off using the dial indicator on the bridge stand to find absolute TDC. The other dial indicator was on the pushrod. I also used a bent copper wire for the degree wheel pointer. Solid lifters are not needed for this method.
I verified all 16 lobes using this method. Very tedious work!
The only thing I didn't have that would have helped is the tapered washer to centralize the degree wheel on the crank snout. I ended up taking the big washer from the ARP crank bolt and gluing it to the degree wheel in the center.
Here is the tools list:
Degree wheel, Comp Cams 9" 4790 - $17
Bridge stand, Proform 66797 - $40
Dial indicator, Proform 66962 - $22 ea, 2x
Old Jun 29, 2013 | 03:13 PM
showvette's Avatar
Thanks. Stuff should be easy enough to get my hands on.
Old Jul 1, 2013 | 03:22 PM
JakeFusion's Avatar
Super Hulk Smash
I bought the Comp kit. It includes the crank fitting, which is like $50 by itself. Otherwise, you're paying a Comp tax on everything else. I need to get a second Dial indicator so I can check TDC on the piston and the cam at the same time, though I have a cam doctor report on the cam. So maybe I don't need to verify the cam itself...
