anyone running a cam WITHOUT a converter?
i ordered this cam 224/228 .567/.571 113 LSA and I don't really WANT to get a converter for a couple of months... money is an issue as well....
lata
Bill
I would recommend SS 4000 by TCI, 2.7 str.
Even if you want to put the cam on you'll need matching valvetrain. Good cam BTW.
im an m6 but rode in a stalled a4
No you dont need one, it isn't something that is required, just something that is smart to do. I really like that cam as it is very good for almost all your need, and is good for power adders as well. Anyways if you are not racing then you can do the cam but you would be better off doing the converter first. You might want to save some money and do the cam and heads at the same time. Save you some money in the future for labor.
I would defentially not do anything smaller than a 3500 stall and would suggest a 3800 or 4000 as well.
Remember to add this cam you will need springs and a good timing chain would be smart as well.
Good luck
1. Make your car stall quite a bit without tuning.
b. Give you that lopey sound you are probably looking for.
3. Make you really want to do more to your car.
Let me run you through the progress of my mods in the 1/4
BBK, GMAF, Hooker CB, FIPK = 13.2 sec
above + 3:73 gears + 100 shot dry N2O = 12.5 sec
Above + TCI 3500 = 11.91 sec (Gain of .59)
Above with cutout/ no cats = 11.75 sec
And finally with a wide open shot of dry (No jets) 11.38 sec
Stock cam/ no headers
So .59 seconds with just a converter is the best bang for the money. I challenge any small cam to have done the same without heads.
Brian
santino04: did you car tune easily?? what is the lsa on your car?
no way......
