Rod bolt question? 8740 or 2000
The stock bolts do well, don't they?
The aftermarket rods have 7/16 bolts. The 8470 is better than stock.
The 2000 is only a little better than the 8470.
Ron
and as others have said, its RPMs that drive the need for bolts with a higher preload. I recommend checking the dynamic forces on the rod bolts against what preload you can achieve, verified with a bolt stretch gauge. 8740 should be good to around 7000 or so, based on the last time I checked (assuming reasonable conservatism and contingencies).
I wouldn't bother with the 2000's, they're not much stronger, not enough to warrant spending more.
Lots of old BBC's were rebuilt with 3/8" stock thru-bolt rods and spun to 7K plus, swinging big ol' heavy pistons. Don't overthink it, but it's good to think everything through and determine where to spend your hard earned cash.
Same reason you get arp main studs, a lot of people don't need them for their 500-600 hp builds.. But they do it for peace of mind..
You think maybe they leave the crown thicker if a piston will see the extra load of boost or nitrous?
