Milled .030 243's/799's on 00' 5.3L
Old 08-06-2013, 12:39 PM
MIKELMOTORCYCLE3398's Avatar
Default Milled .030 243's/799's on 00' 5.3L
How much HP do you think I will pick up with this seap alone? I have a hotcam, LT's and CAI already. I can get the heads, gaskets and bolts for $500 Id like to see a 40hp gain on the dyno. U think its worth it?
Old 08-06-2013, 01:47 PM
Slimsilverado's Avatar
Your not gonna get 40hp IMO.
Old 08-06-2013, 02:24 PM
Marc 85Z28's Avatar
If measured at the crank, 35-40 seems reasonable.
Old 08-06-2013, 04:34 PM
wildcamaro's Avatar
If you get 40hp I will def be milling mine 30 thousandths lol
Old 08-06-2013, 05:55 PM
redtan's Avatar
Not even close on the 40hp. The 5.3 heads are already high comp, so milled 243s won't gain you that much compression. That said, the 243s are an improvement flow wise so you will get some power there. Just not 40hp.
Old 08-06-2013, 07:42 PM
wildcamaro's Avatar
My sentiments exactly...
Old 08-06-2013, 08:05 PM
Thats what i was thinking. I want to mill to keep compression, just wonder if they flow that much better. I really need some more top end flow with the cam and figure this would provide it.
Old 08-06-2013, 09:57 PM
redtan's Avatar
The hotcam isn't exactly a big cam that needs killer head flow, especially on a 5.3.
Now if you had a decent cam in there, a set of 243s might gain you a good amount of power. On the tiny hot cam, not really.
Old 08-07-2013, 04:46 PM
SNLPerformance's Avatar
When Gm swapped to the 799 heads on a stock 5.3 I believe the difference was 15hp, you're getting a tiny compression bump milled and like mentioned the hot cam doesn't have anymore lift than a stock LS2 cam so I'd say 20-25hp is my guess.
Old 08-07-2013, 05:48 PM
garygnu's Avatar
what I was thinking also ,15 rwhp gain .
Old 02-06-2024, 04:54 PM
learning101's Avatar
ok now what if you add flat top pistons or dish better and deal with the lose compression
Old 02-07-2024, 12:02 AM
Received 3,055 Likes on 2,379 Posts
Who are you asking? You're replying to an 11-year old thread
Old 02-07-2024, 08:30 AM
1988montecarloss's Avatar
internet is hard
The following users liked this post:
G Atsma (02-07-2024)
Quick Reply: Milled .030 243's/799's on 00' 5.3L
