High Torque Cams
Old Aug 26, 2013 | 02:31 PM
  #41
MikeWS6's Avatar
Originally Posted by 99Bluz28
MikeWS6, what's the chamber size on your heads, and what's the lsa on your cam..?
It's on 112 lsa. Heads Are tsp prc 2.5 5.3 cncd so 58-63 I think.
Old Aug 26, 2013 | 02:45 PM
  #42
studderin's Avatar
if you want some great low mod tq, its not all the cam. Good heads, and compression.
Newera has done some good street tq cam cars, then added good heads and gain at all RPMs 30-40wtq ! good hp say 450whp, but then 430+ wtq. Compair that to average bolt on "tq" cam 228 whatever. you get 385/400, tq 370-380 setup. then adding a budget cnc ported head it makes 420-440 whp but the tq is 390-400. Were good heads are were the TQ is with the same cam.
Its not all the cam you need to talk about, and have these thread go on, and on for pages. Picking out a custom cam in dur. @ 05 differences 1-4*. Your not going find a difference of 15-20 wtq in that. I bet a good running SBE with great heads and bolt ons, will make within 10 numbers on any 224-228* int 228-232* ext .590-.630 lifts.
Its not cheap, but Ggod heads and compression are were its at, then any cam will be a hero then.
setups like this
I looked, and don't think I posted this car with this SSHT cam on here. I did on a local site, this was back in 2007 when I was working at newera. I think this was winter time,too and we had some time. To do this same day, right on the dyno. (I think the base was the day before) But it was all at the same time. I think the fast92 just came out too.
Originally Posted by Studderin
This is with The streetsweeper HT (228/232) cam and ET 215 CC heads with an unported FAST 92 intake , the choker is that it has SLP headers with cats but it is a well matched street combo , the below graph shows when we dynoed it stock (with borla exhaust) and then added the SSHT cam with full bolt ons , then when we added the ET 215 cc heads with the FAST 92 intake.
https://ls1tech.com/forums/14331199-post31.html
Old Aug 26, 2013 | 03:08 PM
  #43
studderin's Avatar
https://ls1tech.com/forums/dynamomet...oke-400-a.html
I know thats not what this thread is looking at cam/street wise. But I hear from alot of people that think a smaller cam will make more tq, and when you got bigger you lose tq. And you have to rev it more to make more power, but the cam will have less tq. Thats not always true, Big cams make big power AND big (high) tq. A big cam is not for everyone thats for sure. And the "low" rpm some people want to use is all over, I think under 5K is the low end of my car haha But some try to look at 2,500-3,500 range, nothing wrong with that I guess. But I think the cars not setup right if you looking "big" tq, for h/c setup in that range, and your tiring to slice atoms with a hatchet. ( haha I donno there some old saying out there like that)
Old Aug 26, 2013 | 03:17 PM
  #44
alans02z's Avatar
SSHT. Hasnt been hard on the valvetrain and works very well.
Old Aug 26, 2013 | 06:11 PM
  #45
Apocolipse's Avatar
I heard their ramps really kill the springs... Hmmmmm
Need to keep researching!
Old Aug 27, 2013 | 07:50 AM
  #46
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Any cam can kill springs if it isn't set up properly. Heavy wall pushrods, shimming to within .050 of coil bind, checking proper install height, going with the springs the person selecting the cam tells you to... Things like that.
I wouldn't consider my cam a "TQ Cam" but I'm damn proud of my numbers. I attribute a lot if that to the AFR's.
Like studderin mentioned, good heads and compression are your best friends.
Here's my graph. See for yourself.
Old Aug 27, 2013 | 08:30 AM
  #47
Ed Curtis's Avatar
I have to tread lightly on here - but - there's more to valve spring life than "just" the camshaft.
While it's true a lot of camshaft designers tend to concentrate only on using the latest and greatest catalog lobes to stay current, the entire valvetrain "package" is what must be properly matched to the application or all hell breaks loose.
Even if the plan is to use the most aggressive lobes available, the ones you would assume will destroy valve spring life, they can survive if the correct peripherals are used with the profile. Bottom line - there is a big difference between a price point cam kit and one which is designed to perfectly match the application.
The SSHT noted in Johnnie's post is a well proven piece. As a matter of fact, it works so well that there have been a lot of people attempting to copy it but because these aren't catalog lobes, they can only attempt to do it.
If Johnnie wants to share, the boys at New Era have done a lot of testing and in every case, the clones to the SSHT, the original StreetSweeper and even the Hellion have fallen short in both peak and average power numbers to the real McCoys. Mike and crew are very thorough when they are doing the R&D so I have faith in the results.
Old Aug 27, 2013 | 08:45 AM
  #48
Apocolipse's Avatar
For sure its all in the combo. Lighter valve train, better quality springs, proper pre-loads.
I am for sure interested in your HT cam, and I would not buy a knock-off. The powerband is perfect for where I want to be.
That hellraiser cam looks MEAN!
I am going to be shaving my heads, running a thin cometic for quench... would you still recommend the streetsweeper? Or is that hellraiser better? PTV with shaved heads and gaskets?
Old Aug 27, 2013 | 12:43 PM
  #49
DACTARI's Avatar
The cam my tuner specced for my CAI/headers LS2 CTS-v is similar to the Hellraiser, but a hair smaller. The Hellraiser is 229/236 111+3. My tuner usually specs a 228/234 110+3 cam for lighter cars he builds (e.g., F-bodies), but specced a 228/236 111+3 to bring the torque curve down lower to motivate the big V1 and carry it longer. The result was an extremely flat torque curve. It looks like I reach 350lb-ft sooner than the Hellraiser on your car. I hit 350 just after 3K RPM, and am almost at peak torque at 3.5K RPM, and the torque carries all the way to about 5200 before it starts falling off. My peak numbers are falling a little short of expectations due to the restrictive LS2 intake. I now have a FAST102 and LS7 clutch with 20lb flywheel-- car is being tuned as we speak and I should have new dyno numbers soon. Here is the pre-FAST dyno sheet, SAE corrected:
Attachment 726924
Old Aug 27, 2013 | 01:24 PM
  #50
BKsNHRA's Avatar
These are not the best but this is a eps 226-230 112+2 cam. Longtubes, tsp ypipe and magnaflow cat back. Car had 3.73 gear. Everything else was bone stock.
Old Aug 27, 2013 | 01:59 PM
  #51
Sean At CBM's Avatar
Comp/CBM 450
- 220/228 duration
- .581/.588 Lift
- 113 Lobe center
Idle KPA between 35-40. Has a slight lope. GM yellow valve springs required. 1500-6000 power band
Old Aug 27, 2013 | 03:02 PM
  #52
PREDATOR-Z's Avatar
Originally Posted by Sean At CBM
Comp/CBM 450
- 220/228 duration
- .581/.588 Lift
- 113 Lobe center
That looks like Comp XER lobes. IMO you better have better than GM yellow for those lobes.
Old Aug 27, 2013 | 04:03 PM
  #53
BKsNHRA's Avatar
That's what I was thinking.
Old Aug 27, 2013 | 04:41 PM
  #54
studderin's Avatar
am I missing something???? 22x and 23x cams..... some of those Tq curves and numbers you can get with with a bolt on LS6 or LS2 car (stock cam).
Old Aug 27, 2013 | 04:51 PM
  #55
DACTARI's Avatar
Drivetrain loss for the V1 is significant. They always dyno lower than GTOs, which themselves dyno lower than Vettes and F-bodies.
Old Aug 27, 2013 | 06:17 PM
  #56
Apocolipse's Avatar
Hmmmmm
So many dam choices and variables! If you want the tq... Smaller cc intake runner and higher compression for sure...
Ed's streetsweeper HT
Texas speed PRC stage 2.5 5.3 heads (not ls6 so it will have a smaller cc without being decked = more ptv clearance?)
Their upgraded spring package for the extra 50 bucks for 0.675" springs
Cometic 0.041 MLS increase quench
Which pushrods? Hardened comp eng?
Deck head 0.0?? For around 11-11.5:1 compression
5.3L flat top bottom end L33
What's the DCR in that?
Run M6 trans... Alum fly... 390 or 410 gears in a C5.... Win? Or am I off in something...
Old Aug 27, 2013 | 06:35 PM
  #57
MMMichael's Avatar
Yeah... I was afraid this question might be like the chicken or the egg! haha
There are sooooo many variables that come into play with power in general.
I'm mainly just wanting a street friendly cam, not necessarily a driver friendly, but something that will really roast the tires.
I've narrowed it down to a few so far, which you guys have helped with immensely.
Thanks!
Old Aug 29, 2013 | 08:49 AM
  #58
Apocolipse's Avatar
Discussion not over! lol dont be signing it off already.
Still lots to discuss instead of starting a new thread in 3 weeks again lol
Old Aug 29, 2013 | 01:07 PM
  #59
99Bluz28's Avatar
Thanks!
IMO, it would be a good idea to start calling some of the sponsors and give them the spill on what you're looking for, and give them as much info as possible. I'd call/email at least 4, then sit down a compare what they're suggesting. This should at least narrow down your cam choice ,even more.
Tick performance, EPS, Futral Motorsports
Flowtech Induction, email: info@flowtechinduction.com
Old Aug 29, 2013 | 01:31 PM
  #60
slt200mph's Avatar
I made 452/418 with a 224/228 .595/.595 110+0 LSA. using TEA 5.3 heads milled down to 59CC chambers which give it 11.4 to 1 compression. 375 RWTQ @ 3200 rpms means great throttle response to say the least. With those small intake runners you keep your intake velocity nice and high. The heads flow 316 on the intake side. Valve springs last 50,000 miles. This combo works well for me. Nuff said.
