How do i make ls1 intake fit with truck accessories?
Okay so i ordered a dirty dingo bracket for my r4 a/c ,got a ly6 water pump to clear the ls1 intake manifold but when i tried putting the alternator/power steering bracket the pulley would touch the throttle body....what can i do to make it fit?? thanks
There should be a post on ls1tech aoubt this. Anyway, U have to cut off the lower corner of the ALT bracket.
Just grab a longer bolt and more the idler to a lower position. I have a ls1 FAST90 on my PU.
Check out performance trucks .net n C if U can this info there.
If not I can snap a pic of mine 2maro morning.
Are you putting an LS in a 91 pickup as your screen name suggests?
If so I would try and use a truck intake as they are better than the LS1 intake. Truck intakes are EASY to find since trucks are plentiful and the engines are often used in retrofits but the intakes rarely clear in car applications.
Im running a car intake with truck accessories. You have to relocate the idler pulley below the alternator. I used the dirty dingo kit. Then you have to cut off the ears on the bracket so tb sensors clear. IIRC you need to run the car steam vent too.
