Best Oil Pump?
Old Jan 4, 2014 | 07:19 PM
Treyvs's Avatar
Default Best Oil Pump?
Melling M295? Stock GM? Ported LS6?
I am putting this on my 5.3L that will eventually see about 7psi from a procharger, but won't ever see serious abuse. I do want this engine to last for quite awhile once it is put into the truck. Any recommendations as to which oil pump to go with?
Old Jan 4, 2014 | 07:55 PM
BKsNHRA's Avatar
I bought a tick performance ported ls 6 pump. I saw a nice bump in pressure. Cant go wrong with it. Im not using it on a boosted application though so you might wanna see what the boosted guys say.
Old Jan 4, 2014 | 08:04 PM
Treyvs's Avatar
Which o-ring did you use with the Tick pump?
Old Jan 4, 2014 | 08:26 PM
1BAD98LS1's Avatar
Ported LS6 here...
Old Jan 4, 2014 | 08:27 PM
BKsNHRA's Avatar
I got the blue oring with it.
Old Jan 4, 2014 | 08:30 PM
cmac06's Avatar
http://schumannsdynamicperformance.c...130998/LSSSRXV
BKsNHRA's Avatar
Now that I think about it I have installed two of these. One on my ls1 and one on a 6.0 I install in a trans am. I like them and so far have had good luck with them so ill keep using them.
Old Jan 4, 2014 | 08:49 PM
GTO1_OHIO's Avatar
Katech
https://ls1tech.com/forums/generatio...-oil-pump.html
Old Jan 4, 2014 | 09:00 PM
Treyvs's Avatar
Was it included with the pump itself?
Old Jan 4, 2014 | 09:22 PM
1BAD98LS1's Avatar
Most of the time they come with it from whoever ported it. I got a MAMO ported pump and it came with the blue o-ring.
Old Jan 5, 2014 | 01:53 PM
Hubbard Racing Inc's Avatar
We have sold hundreds of our HRI Ported LS6 oil pumps to members of this forum with nothing but good reviews! Feel free to check them out and let me know if you have any questions!
http://hubbardracinginc.com/product/...-oil-pump-new/
If you use coupon code 'pump10' you'll get $10 off at checkout!
hope this helps!
Ethan
Old Jan 5, 2014 | 02:13 PM
KCS's Avatar
KCS
Moderator
I like the Melling stuff, but I think any of those pumps would be fine.
Old Jan 5, 2014 | 05:41 PM
Treyvs's Avatar
Purchased a Melling 10295. Seems to be the best unit for my application. Thanks everyone!
Old Jan 5, 2014 | 05:47 PM
JakeFusion's Avatar
Super Hulk Smash
With the Melling, make sure you clean it out. There can be trash in there that will ruin the pump if not cleaned out. Just take it apart, wipe it down, and put it back together before running it.
Old Jan 5, 2014 | 05:48 PM
Treyvs's Avatar
Will do, thank you. Is there a torque spec for the cover bolts?
Old Jan 5, 2014 | 05:54 PM
JakeFusion's Avatar
Super Hulk Smash
I think Melling provides. I know GM specs, but don't have the Melling handy.
Old Jan 5, 2014 | 06:10 PM
mjs1012's Avatar
I have a melling m295 pump and its provides a good amount of pressure. It think it cost me $60 so for the money its good imo.
Old Jan 5, 2014 | 06:13 PM
KCS's Avatar
KCS
Moderator
It's the same as GM oil pumps, 106in-lbs.
Old Jan 5, 2014 | 06:56 PM
Treyvs's Avatar
Thank you.
Old Jan 6, 2014 | 03:46 PM
98WhiteLsX's Avatar
Good info in here. Ill be using a ported ls6
