which pickup tube o-ring should I use? *PIC*
Old 01-20-2014, 06:45 AM
JDMC5's Avatar
Default which pickup tube o-ring should I use? *PIC*
Its the felpro kit listed on the paper in the background. I used the black one and it went on good, I just want to be sure I'm using the right one. I read the red one is for a pickup tube that is recessed, not sure on the green one.
Old 01-20-2014, 06:51 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
IIRC it should be the black one.
Old 01-20-2014, 11:28 AM
Treyvs's Avatar
This instruction sheet came with my Melling 10295. It is somewhat of a challenging diagram to understand if you don't know what you're looking for, but it helped me.
I also vote for a black o-ring on your application.
Attached Thumbnails which pickup tube o-ring should I use? *PIC*-img_1486done.jpg
Old 01-20-2014, 11:29 AM
fruitsalad's Avatar
Green is truck pickup tube, red looks way too thick, black looks like the winner.
Old 01-20-2014, 11:31 AM
JDMC5's Avatar
awesome, thanks for the support guys. I went with the black one and it popped in just fine. Thanks!!
Old 01-22-2014, 08:15 AM
soundengineer's Avatar
I would not use any of them...
GM had a revision of the O-Ring...
go into a GM Dealership and get the right one... which I believe is a Blueish color now.
Old 01-22-2014, 09:35 AM
JDMC5's Avatar
whats the difference?
Old 01-22-2014, 09:41 AM
not sure...
but at a minimum, I would go in, and see exactly which one they want you to use instead of asking people to guess from an internet picture.
if the o-ring doesnt seal properly, you will have oil issues
at a minimum, its worth the drive to the dealership to see what the GM recommended part it.
take the ones you have with you.
Old 01-22-2014, 11:06 AM
JDMC5's Avatar
hmmm, i thought maybe felpro knew what they were doing....
Old 01-22-2014, 11:16 AM
its not supposed to fit loose...its supposed to be hard to get the pickup into the pump...
This is a very crucial seal...it needs to be tight
03Sssnake's Avatar
I used the red fel-pro on my 99, it is thicker, just lubed it with motor oil. The fitment was a little snug, but the pickup tube did fully seat and I have no pressure issues. Believe that part number 72401 is the part I used.
Old 01-22-2014, 11:33 AM
JDMC5's Avatar
yea it was tight, I had to force it in. I had plenty of lucas assy lube on it too. It had a good positive feel, I'm pretty positive it will work.
Old 01-22-2014, 11:34 AM
JDMC5's Avatar
that's the same one I bought, did you use the black one?
Old 01-22-2014, 11:55 AM
Forcefed86's Avatar
I used the orange one. Orange seals came off my 2006 4.8 and 2008 5.3.
PN:12584922
https://sdparts.com/details/gm-facto...parts/12584922
For future reference:
GM Oil Pick-Up Tube O-Ring (1st Design)
12557752
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
Old 01-22-2014, 12:35 PM
03Sssnake's Avatar
Used the red one...I think I had pinched the black one and could not use it...I went to the parts store and picked up that red fel-pro seal after searching post here.
Old 01-22-2014, 01:36 PM
JDMC5's Avatar
really? and it worked? it was way too big..
Quick Reply: which pickup tube o-ring should I use? *PIC*
