jesel street/strip roller rockers
can these rockers be used with a solid roller setup. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
MTI, our sponsor, sells these...
...the non-adjustible shaft rockers are $700
..the adjustible shaft rockers are $1,000
WOW THESE ARE COSTLY!!!!!
Thunder Racing: 101-20041 T&D Machine Shaft Mount Rockers, LS1 1.7 Ratio $835.33 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> A little better
8 SEC SLOPPY SHOT!!!
I have jessel non adjustble and i had to gut the valve covers and do some grinding. if i did it again i would get ether tall valvecovers or spacers and t&d rocker for solid roller down the road.
I guess you guys haven't heard about the Yella Terra Stealth roller rockers? They are pedestal/shaft design and fit with no modification req'd. I put a set of these on when I did my head swap and am extremely impressed with them. They are actually easier to put on than the stockers...no aligning on the stem....only one way to go on. I did use the supplied spacers under the pedestals to get the right lifter loading...the instructions take you in depth through this process and is kinda cool to tweak them for your setup. Best part is the cost...$500 shipped. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Mark at Raging Motorsports ----------------->
has the connection on getting them for a little better price....
One more thing...I have the TR224 and had a fairly noisey drivetrain...after installing these it quietened down a bunch. Horsepower gains are supposed to be a benefit(which is kinda hard for me to get a sotp difference due to head install also)..but just having a quieter engine was worth the money. I should also mention that I went to a double spring also, which probably helped.
I have a 99 those jessel rockers are big when i first started my motor the valve covers were dancing all over the place from rubbing it took me three times before thay cleard and i had to take all the baffles out and do some miner ginding you know when they rub trust me
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by C$:
<strong> Jesel definitely makes an adjustable rocker kit for the ls1, they also make a non adjustable rocker. Just call them uup </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Got them! They are sweet. Also surprisingly quiet for a solid roller, even this monster one I am running.
You do need new valve covers and/or valve cover spacers to run them.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a set of brand new Jesel non adjustable rockers for sale here.
https://ls1tech.com/ubb/cgi-bin/ulti...=011017#000013
