Short duration, Tight LSA Cams
You'll never reach the peak of the cam, unless you rev to 6800. (Over the LS1 specs for the "ROD BOLTS")
(216/220) peaks at 6100>6300, is capable of 400 rwhp and a little more
Did I forget loves N2O??
I had a cam that was way to big long ago (270/270 in a SBC,) so I was going to get a 218/218 .563 cam for my 2001 SS, but I'm glad I didn't. When you have a cam with short duration and a lot of lift, that makes more valvetrain noise and is harder on springs. Anyway, you small cam guys can use whatever you like, I was just trying to save you the trouble of having to upgrade your cam twice.
XE-R lazy???
You are right, we can't agree on anything! LOL
Does it say on the cam card what lobes it has?? If so where?
216/220 is XR269HR-14 part # 54-414-11
I think my problem, is I don't have much desire shifting any higher than 6,000. I'm looking for a cam with a lot of meat in the midrange............
If I'm hearing you guys right though, even something like a TR224 will make as much, if not more power down low (from like 2K to 4K for example), even than smaller cams?
One other thing. Can anyone explain the huge torque way down low, in the following link? Is that the 2800 stall in the car? "Shirley" that's not just the cam, is it?
Mr. Vinci, ready to "CONVINCI" me on one of your cams?
What kind of spring change interval would you recommend for your car cams?
I'm a little nervous about spring life, because I seem to manage to drive about 30K a year... and a good four of those months don't provide me with good spring changing weather under the tree in the backyard.
I'm in the same boat these days
Also, anyone have any sound clips of these two or know where I could find them? I'd like to know how "Powerful, Choppy Idle" sounds
Joe - On this page... It starts off explaining your accelerated lift rockers. It then mentions the cams, and it says that these cams we're all looking at are designed to take advantage of your rockers.
Do we need to run your rockers to take full advantage of your cams? Would there be any side effects if we don't? (lack of power down low, lazier looking/acting lobes, etc.)
Also, I see a lot of your ads are Crane ads. The specs of some of your cams look to be Crane lobes... Does Crane grind your cams?
Consensus in the truck forum is, off the shelf Crane cams/lobes don't seem to work so hot in trucks due to lazy lobes and lack of torque where trucks need it... down low and midrange. (this is all hearsay to me, I have no first hand experience.) Most truck guys prefer the Comp Cams stuff.
I'm not sure why, but Crane also don't seem so popular on the car side either. If Crane does do your grinding, are your new cam profiles designed to overcome the above issue, without the use of special rockers?
I just got around to *reading* the ads, and Crane mentions your a customer of theirs.
However, if I had it to do again; I would have gone with the Comp LS6 Street Replacement Cam 212/218 .550 114 lsa (?) might be a 116lsa. which does not require any tuning.
I don't know what you guys in Hawaii pay for Nitrous, but I think that's your best bet. A 50 dry shot should get you where you want to be and the bottle will last a long time.
