5.3 Truck LS Help
Old Feb 25, 2014 | 10:05 PM
1972 LS Nova's Avatar
Default 5.3 Truck LS Help
There's a junkyard near my house that has a running 5.3 long block out of a 2001 Chevrolet Silverado 1500 for 200 bucks, which I think is quite a steal. I'm a first time engine builder (I hesitate to even say that) and I'm looking to take said powerplant and get around 425-450 out of it. The eventual goal is to put it into a, you guessed it, 1972 Nova that I picked up also for pretty low dollar. What parts can I put on it for under $1,500.00 that will get me in that ballpark horsepower number? The car is intended to be a daily driver that just has some getup to it when I want to bury my foot in the loud pedal by the way. Any help is appreciated. Thanks in advance.
-Max
Old Feb 26, 2014 | 07:49 PM
96capricemgr's Avatar
Flywheel HP you can easily get there without spending much on the engine, certainly no "building".
What does the $1500 have to buy? Have you considered the fuel and exhaust systems, wiring etc?
Old Feb 26, 2014 | 08:37 PM
I already have a fuel cell, lines, pump, etc. budgeted into another part of the project and I have the wiring because it comes with the engine (As does intake, injectors, accessory drive).
-Max
Old Feb 26, 2014 | 09:20 PM
Justhereforinfo's Avatar
-Max
A running 5.3 long block, and the wiring, intake, injectors, and acc's for $200???
That IS a steal.
Old Feb 26, 2014 | 09:30 PM
TruckerBomb's Avatar
That IS a steal.
truth, I got my 5.3 with no wiring, acc, or injectors for 300... and THAT is cheap by most standards... I'd jump on it man. With that budget, that motor is a great starting point to get the power you're wanting.
Old Feb 27, 2014 | 09:40 PM
Thanks for the words of encouragement. A rather am in dire need of knowledge about what kind of cam I should go for, if I need to replace pistons, etc. I'm going for kind of a pro-touring/autocross feel/build. Any parts or manufacturers would be wonderful.
-Max
Old Feb 27, 2014 | 09:49 PM
HexenLord's Avatar
I've seen a number of stock 5.3 dynos that were around 330 at the flywheel.
A simple tune puts them at ~350. From there a nice cam will get you another 50 HP. Doesn't have to be big. TSP 224r is a good sized cam for a very mild 5.3. Now you're at 400. Long-tubes and a nice exhaust could inch you up to that 425. That should put you under your $1500 budget.
500 for cam/springs, 500 for headers/exhaust, 500 for a tune. Each of those could sway $200 depending on the effort you put into them.
Old Feb 27, 2014 | 10:17 PM
Major thanks man. You have links where to get these? I'm not caught up on my acronyms so I don't know what TSP means.
Old Feb 28, 2014 | 08:59 AM
bboyxclub's Avatar
Ill say buy it before it goes away.. Just 1 accessory is prob worth that much alone.
Old Feb 28, 2014 | 09:32 PM
HexenLord's Avatar
TSP is texas speed.
http://www.texas-speed.com/p-1146-te...-camshaft.aspx
Camshafts similar to these pop up on the for sale forums quite often. Nothing wrong with running a used cam if its still in good shape. This is where that $200 swing comes into play. Most new camshafts are going to be very simliar to this one in price. Its a very mild cam that performs very well. PAC 1218 springs can be found cheap and are a great bang for the buck for any cam below .600" lift.
New headers are going to be about $500. Exhaust will be another $200 unless you want true duals with mufflers out the back. Thats the $200 swing. There are also some cheap longtubes that fit Nova LS swaps and are about $250. A nice cheap short exhaust the dumps before the rear axle would be another $100 or so, so there's your $200 swing in the other direction.
A tune is the other. You can buy HPtuners yourself for $500 and tune it. Or you can find a shop that knows HP tuners and they'll probably charge you roughly the same. You could do it cheaper if you found someone local with some leftover credits on their HPtuners that would give you a quick tune for the cost of credits. You might be able to knock more than $200 of from the $500 if you do it that way.
Old Mar 1, 2014 | 11:26 PM
this.
seriously, buy it, you won't regret it.
if you change your mind, you'll be able to sell it for $500 easy.
Old Mar 1, 2014 | 11:54 PM
cbenn47's Avatar
I paid $700.00 for a complete 5.3 with all accessories, computer, and DBW w/controler, then now in the process of rebuilding it, that is costing me with all the toys I'm adding, good luck.
