ls1 block not enough compression for bigger cams?
larger cam meaning 23x/23x or 23x/24x such as the popular ms3 or ms4
Obviously more compression will help those bigger cams down low, but it's not like it's not going to run if you put such a cam in. It will just be lazy as heck below 4000rpm.
yeah basically he was saying you cant really give what that cam needs
"Big" cams with a lot of duration and overlap don't run very in low compression engines. Because of the overlap, they don't build cylinder pressure. And cylinder pressure is what makes power. The engine will still run. But it just may not be the right cam for that engine combo. It's a system, and all the parts need to match.
Keep in mind that us old farts can remember when 9.0 was considered high compression, and got really excited about 10.0. How old is your friend?
Sometimes you can put in a "smaller" cam and make more power under the curve by giving up a little off the top.
The problem normally comes from putting the wrong cam in for the wrong reasons in the wrong combination. Being cheap is never a good excuse.
But I road race. I don't really care about peak HP numbers. I want torque, and a lot of it. I want lots of area under the curve. I want a broad flat torque curve that will pull me out of a corner and down the back stretch. The flatter the torque curve is the happier I am. That means less time wasted shifting.
When I build a street engine, I want pretty much the same thing. Lots of torque in a light weight car is a real joy to drive.
New custom cam from us is 385 shipped.
Quite a few new cams are that price or higher from some companies.
