Knock when cold
Old Mar 7, 2014 | 10:24 AM
idahoz28's Avatar
Default Knock when cold
Both my 2000 & 2001 Z28's knock quite a bit even at low speeds when cold. Is this piston slap, detonation, or anything serious that I should worry about?? It quiets down after a few minutes when they get warm. Both are fairly low mile cars. Could this be carbon buildup that is causing it?? Any remedies out there???
Old Mar 7, 2014 | 10:44 AM
JRENIGAR's Avatar
Mine is doing the same thing. I seafoamed the upper part of the engine and when it didnt fix the issue I thought it was piston slap. I didnt worry about it and figured there was nothing short of a rebuild that was gonna fix it. I just got it back from an LS specialty shop and they told me its the lifters gummed up probably from a lack of maitenance from a previous owner. I just put some seafoam in the oil yesterday afternoon and drove about 35 miles non stop to the house. I went out at 4:00 this morning and started it to go to work and the noise has drastically reduced but not totally gone. The temp was about 30 degrees outside this morning and it would have normally sounded like a diamondback rattlesnake before the seafoam so Im gonna give it a couple of hundred miles to see what happens. Hope this works or its off with her heads!!! BTW, does anyone know if the rocker bolts are TTY?
Old Mar 7, 2014 | 12:00 PM
Cudberg12's Avatar
Default Have you ever gotten knocked out cold?
What do you remember about it? I stepped on a soccer ball once and flew backwards and landed on my head on the blacktop, knocking myself out cold. Next thing I knew, I was sitting at a friend's kitchen table with an icepack on my head
Old Mar 7, 2014 | 12:21 PM
idahoz28's Avatar
Strange you say that....... My first LS1 Camaro (a Mystic Green & black convertible Z28) and I were in a head-on crash w/ an F250 (he crossed center lane). I was KO'd by the air bag. Woke up to see his tires in my windshield. I was still in a daze when he put it in reverse, drove off my hood and took off. He had no front plates & the police never found him. Needless to say the Camaro was a total loss. I was very lucky and only needed 40 stitches to my forehead from my wrist watch getting caught between the air bag & my head.
Old Mar 7, 2014 | 01:01 PM
JRENIGAR's Avatar
Say what?
Old Mar 7, 2014 | 03:47 PM
BlueBird346's Avatar
Just sounds like piston slap to me. If it goes away when warmed up.
Old Mar 7, 2014 | 03:56 PM
RockinWs6's Avatar
How much oil do they use? My low mileage WS6 knocks cold and uses too much oil, runs good though.
Old Mar 7, 2014 | 06:02 PM
idahoz28's Avatar
They don't use much oil. Probably 1/2 quart between changes.
Old Mar 7, 2014 | 06:05 PM
RockinWs6's Avatar
Mine has 65k uses at least 2 qts between changes.....Never see it smoke etc but its using it. Mine knocks for the 1st 5 mins then its quiet.
