How far will the stock fuel pump get you?
After all the mods on your engine, how far will the stock fuel pump get you? Or, is it even possible to out grow your stock fuel pump?
Not sure how far the stock fuel pump will get you but I know my build um going with the hotwire racetronix kit from ws6 store. It's like 200 bucks. I don't know your horsepower level or goals. My motor should make around 575 at the crank
This is what I have with the original stock pump: Texas Speed forged shortblock and Stage I LS6 cnc heads milled .035, MS3 cam w/dual springs, LS7 lifters, Fast 102 with 100mm mass air, 42lb injectors.
this may seem like a dumb question lol, does changing ONLY the fuel pump affect the injectors as far as tuning goes? if I install one will I need to adjust my injector rates?
I bought my Racetronix w/ hotwire kit from Hawks on Ebay. the mod wasn't bad at all. I also recommend replacing the fuel level sensor assy while you have the pump and float out of the tank (is only $14 on Ebay). http://www.ebay.com/itm/360849986447...84.m1497.l2649
there are tiny metal contacts on the float sensor dial and they were all broken or barely hanging on - makes sense because sometimes I'd see my gas gauge surging. I've heard others say they saw same thing when they replaced fuel pump.
