Big cam, no tune?
Old 05-17-2004, 11:31 AM
PonyKiln's Avatar
Question Big cam, no tune?
Ok guys I get my cam installed on Wednesday and I cant get it tuned until next week . I'm pretty sure I'll be ok riding around in it but what if I take it to the track? Will I be ok? Cam specs are 231/237 .598/.595 @112 on stock heads. I need advice guys,let me know if I am smoking crack or not.
Old 05-17-2004, 11:36 AM
samz28's Avatar
well if it leans out and you melt a piston, that would suck, but what the heck it's only a block
Old 05-17-2004, 11:37 AM
99WS6LS1T/A's Avatar
I wouldn't take it to the track, get it tuned first. Driving around normal should be fine. You may have to drill your throttle body to get it to idle.
Old 05-17-2004, 11:45 AM
samz28's Avatar
for gods sake DON'T DRILL the TB, tuners will hate you for this...
There's a little screw to adjust the REST TB blade position, get under there and adjust that so the blade is default open more.
Trust me most tuners get pissy when you start drilling holes. "my tune is so good you dont need any hoes". blah blah blah.
lol
Old 05-17-2004, 01:16 PM
Toonz's Avatar
Too bad my tuner is the one that drilled the hole...
Old 05-17-2004, 01:22 PM
killer01ws6's Avatar
Old 05-17-2004, 06:48 PM
PonyKiln's Avatar
My tuner told me to remind the guy installing to drill the throttebody??
Old 05-17-2004, 07:35 PM
B18B1LS1's Avatar
I have the same cam with no tuning and I drive it all the time. And I've made about 10 passes at the track with it, so, I say go for it. I did have to drill the throttle body ALOT to get an idle though. I'm sure you will be down on power and maybe on the rich side without tuning but you can't have a new cam and not get on it!
Jeffrey
Old 05-17-2004, 07:36 PM
Racer99Bird's Avatar
well, what do you know, so did mine !!! but only after he tuned it the first time, and then went for a test drive, still wasn't idling perfectly, then and only then is when he drilled the TB a little bit to help it better, and now, it idles great
Old 05-17-2004, 07:39 PM
pdd
pdd's Avatar
i have the fm11 228'230 and my car would't idle for **** without a tune
Quick Reply: Big cam, no tune?
