Coated or Uncoated Bearings?
I'm ready to order my rotating assembly and don't know which main & rod bearings to order.
I was going to order the Clevite H-Series bearings MS2199H and CB663HN but I don't know if I should spring for the coated or not.
This is going in my street/strip car, not a DD, 408 LQ4 block NA, 11.3 compression.
Any info or advise would be appreciated.
Thanks
Craig
Thanks
Craig
Moderator
I use Polymer Dynamics (PolyDyn) in Houston for coatings. They coated a set of ACL bearings for an LS7 I built, and after about a year of street racing and Texas Mile events making over 800whp on nitrous, the engine was torn down and the coating was still on the bearings.
I like coated bearings because you can use a bearing and have a good safe clearance, but the coating will reduce the actual clearance so that the oil pressure doesn't take such a hit. For example, my engine uses coated ACL bearings for .002-.0025" clearance. Without the clearance, I have as much as .0032" as a margin of safety.
If a situation happens where the journal needs more clearance, the coating is worn away instead of the bearing. The coating doesn't hurt anything if it's worn off and circulating in the oil, but bearing material passing through the engine does.
It's good for extreme builds. It helps on startup when the oil film is very thin and can take more punishment and extend the life of a motor.
