Just bought tsp 228R, have questions
#106
If the machine shop mills my 243 heads, do I need to worry about PTV clearance? Do I need thicker gaskets?
If you have any other advice for swapping heads, please LMK thanks!
Cam specs are 228/228 .588/.588 114lsa
#107
LS1TECH & Trucks Sponsor
We mill more and have enough clearance with our ported heads, but we sink valves to gain extra clearance. We can mill as much as .035" off and still clear a 228R.
#108
I have all exact setup but with 243 heads and 228r on a 112lsa and mine put down 406 at the wheels. So everyone wants to know how much the 243 heads can add so there ya go. Mine TA is a 6-speed as well.
#110
Ok ran for the first time on the track since my Dyno tune. I gained about 40 rwhp and 60 tq.
So i only got 1 run in which could explain my bad time. I turned a 13.1 @ 108. 2.0 60ft. Got a bad launch but I figured I'd trap better or pick up the time down the track. I launch at 2000 rpms. I have drag radials I heated up but I feel there's was water still on them and I may not have burned out of the water box. Just trying to figure this out. DA was around 1000ft. I want to go again next Friday and aim for a much better ET but just seeing if I can get some tips.
I feel I could have done better but my buddies new 15 mustang gt couldnt pull under a 13.2. So right off the bat getting a 13.1 makes me feel a little better.
#112
to give you an example, I did that same cam and all the parts you mentioned in my 99 camaro. I didnt change heads or intake, just cam..
I drove it around for 2 weeks before I got my tune. It honestly ran great and hardly had any driveability issues, I didnt even throw a CEL light. Just make sure youd dont get on it at all. Just to be safe
also did you change from stock injectors?
#113
Just to update. I got the 243s at the machine shop. Getting a valve job and decked. I'm currently looking into options for injectors. Trying to find some inexpensive GTP 36lb injectors.
Then the plan is to get back on the Dyno and see what happens!
#114
Updating this threads. The 243 head swap was a success! Got the GTP injectors on as well working great. I got my aem wideband in and we dialed in the AFR to around 12.5-12.8. It pulls on my buddy's 360rwhp Camaro very easily. Also I just got a nitrous outlet plate kit I have installed and I'm getting ready to get a Dyno tune with a 100 shot.
#115
Im planning to buy a set of the PRC stage 1 ls6 heads, I have the Howard's ASA cam 226/236 .525/.525 @.50 110 LSA, how much can I mill those heads?
