LQ4 into my SS
swapping from ls1:
torquer v3 cam
btr .660 springs
timing chain
oil pump
New:
Ported Fast 102/102 setup
85mm Maf
42lb injectors
racetronix pump/hot wire kit
switching to a ls6 style pcv setup
stock 799 heads
as far as internals on the motor im staying with stock bore and stroke for this year. just a light hone on the cylinder walls. im looking at wiseco flat top pistons with there gfx rings. probly K1 or callies connecting rods.
now I would like to raise the compression somewhere around 11.5 or 12 to 1
(I want to stay on pump gas)so my question is which is better to do. Run a dome piston and get the right headgasket thickness to achieve this or...run a flat top piston and get the heads milled to get the desired compression ratio? any upsides or downsides to either way? everything with be held together with ARP bolts and either ls9 or cometic headgaskets.
any recommendations for rod/main bearing sets? clevite? king?
im hoping to make 500whp on motor and spray a 250 shot on top of it. as far as time goals. low 11's on motor and low 10's on spray. my ls1 made 407whp with a ls6 intake, 853 heads. stock throttle body, and stock compression. I cant see why 500 or more cant be had.
Just looking for overall tips, suggestions, from everyone. thanks!
I'm starting a similar build and decided on Wiseco Pro Tru pistons. They have a 4cc dome and are meant for stock stroke and stock rods, but you can use an aftermarket rod with a .943" pin and 6.098" rod length. With the 64cc chambers and an LS9 head gasket, you're looking at about 11.6:1.
I've used Clevite, ACL, and Federal Mogul bearings and I think you'd be fine with any of those. There are differences, but nothinh I think that would be beneficial unless you were making a lot more power. FWIW, I have ACL's in my 6.2L.
