Would this timing Chain Kit fit
The chain off the 6.0 is better than the LS1 and will work with your existing gears. I'd just do that if you are that hard up on cash. Personally, I prefer to see a beefier chain and billet sprockets, since this sets the timing of the motor and accuracy is paramount, especially when you start running higher performance parts.
It's this one from Summit.
http://www.summitracing.com/parts/sum-g6616-b
As the crank & cam gears are the same, and the LS1 chain has been superseded by it anyway, just get the LS2 chain. It's within your price range:
https://sdparts.com/details/gm-facto...parts/12586482
Also, be wary of cheap knock-off chains and sets, they're everywhere. This is one thing where you want the real McCoy, whether it be a GM or aftermarket brand name chain.
The LS2 engines are also 24x with a 1x cam pickup but it's the block on the cam gear with the sensor through the timing cover.
Later engines are 58x with a 4x cam pickup, also through the timing cover.
Current engines are also 58x/4x but with one bolt through the cam gear.
GM chains themselves interchange for all years. The thicker LS2 chain is what they use now.
I'm doing a big 383 build and I went with a single roller Roll Master set.
