need help on my lsx build!!
Old Jul 9, 2014 | 07:35 AM
lsx1987monte1993's Avatar
Default need help on my lsx build!!
I'm building a cast 6.0 truck motor I need some tips. So far I have all forged internals and a set of the gm small bore l92 heads brand new. Need help on cam selection and if I need to upgrade any of the valve train components. Looking to be at 500-550 n/a and 700 on spray.need a good cam tip also it will be carbed and be back up with a th400
Old Jul 9, 2014 | 07:48 AM
KCS's Avatar
KCS
Moderator
500-550hp at the wheels?
Old Jul 9, 2014 | 07:55 AM
Blackpanther99's Avatar
Custom grind cam, any work done to the heads? What what valvetrain components do you have?
Old Jul 9, 2014 | 08:08 AM
right now its just the stock l92 small bore heads by gm high performance all stock components heres the specs
•LS3/L92 Port Configuration
•''As cast'' runners and combustion chamber
•15? valve angle
•Assembled with 2.00'' intake and 1.55'' exhaust valves
•250cc intake port and 80cc exhaust port
•70cc combustion chamber
•Intake flow - 280 cfm @ .600'' lift / Exhaust flow - 180 cfm @ .700'' lift
•Beehive valve springs
•Uses LS3/L92 style rocker arms (offset)
•3.890'' minimum bore size
•Uses LS3/L92 style intake manifold
and ys i want to acheive 500 at the wheels i know i need to go custom grind just dont know numbers and if any head work in needed this is my first ls build
Old Jul 9, 2014 | 09:14 AM
KCS's Avatar
KCS
Moderator
Ugh 250cc runner on top of a 2" valve and a carb? That might be a little tricky to spec a good cam. I would definitely go custom so you explain the entire build and goals, and have them spec a cam for you. Personally, I would probably be in the neighborhood of 230/240 durations and probably a tight 111 LSA.
Old Jul 9, 2014 | 09:32 AM
i was thinking about going with lunati everyone teels me the off the shelf majic stick cam 3 or 4 by texas speed would work well
Old Jul 9, 2014 | 12:29 PM
Rise of the Phoenix's Avatar
For a few bucks more, why not have someone custom spec you a cam that's tailored to your engine's top end and your goals for the car?
Old Jul 9, 2014 | 01:32 PM
KCS's Avatar
KCS
Moderator
Well, nothing against that cam but it was meant for an LSx with much smaller ports and a plastic manifold. With LS3 ports, LS1 valves, and a single plane intake, it may not work as well.
