Tick SNS Torquer Stage 2 users Come On In!
Old Nov 25, 2015 | 05:58 AM
  #101
Sales@Tick's Avatar
Originally Posted by TrentB
Has anyone run this cam with AI 219 HCR heads with a chamber size around 60.5? I purchased my SNS2 with all the necessities earlier this month. Since then I picked up a cheap set of 241's on craigslist and plan on sending them to AI next week. They suggested a 60.5 cc chamber and said that would be around 11:1. I've been searching for the past day but can't find much information on this combo. Do you guys see any clearance issues?
You will not have any clearance issues with this cam and head combo.
Old Dec 2, 2015 | 01:05 PM
  #102
SCott5's Avatar
I'm leaning towards this cam for my c5z. Anyone else run it in a corvette?
Old Dec 4, 2015 | 12:04 PM
  #103
TrentB's Avatar
What would you guys run for a head gasket? Would it be best to run stock thickness or could i run a thinner gasket? I plan on running a 100 shot.
Old Apr 17, 2016 | 01:49 AM
  #104
VKANGRY1's Avatar
another 1 here from Australia. in a ls1 that's fitted to an 85 model commodore/ older model of your g8
Tick SNS Stage 2 cam Version(Regular/Mild): regular
Heads ported? If yes, by who?: 241's ported by APM
Chamber size: not sure
Head gasket: stock gaskets
Flycut? if so, how much? If no, what was your clearance?: No
Exhaust, intake mods: 1 3/4 primarys xpipe twin 3inch, stock ls1 intake
Rear gears: 3.73
Rear (i.e 9", S60, 10 bolt etc)
Auto or manual trans: Auto 3600 stall
Dyno HP/TQ: 387.6(b) not sure on tq or what rpm etc it was
Type of dyno? (i.e. mustang, dynojet): Dyno Dynamics
Track Times and Speed: hasn't been down 1/4 yet
Old May 17, 2016 | 08:42 PM
  #105
blk99camaro's Avatar
My SNS2 (LS2) shipped out today, cant wait to get my beater back together, the results I have seen here are promising. I did go with the LS2 version for a few different reasons, mainly flexibility on upgrades, and the cam specs were more in line with what I was recommended by other "cam guys". Seemed like a fantastic off the shelf cam for my setup.
Old May 18, 2016 | 09:37 PM
  #106
HeavyMetl's Avatar
Tick SNS2 (regular)
AI 226 243's
Stock FAST 102
92MM TB
T56
Moser 9" w/4.30's
26" stiff wall ET Drag
Monster Level III clutch
7.15@96.36 1/8th mile.
3450lb raceweight Thirdgen Camaro
The SNS2 makes great torque and carries the power, the resulting ET really surprised.
Old Feb 6, 2017 | 08:20 PM
  #107
sjcrft19's Avatar
Tick SNS Stage 2 cam Version (Regular/Mild): reg ls2
Heads: prc stage 2.5 5.3l heads
Ported? If yes, by who?:
Chamber size:62
Head gasket:.51 gm mls
Flycut? if so, how much?:no
Exhaust, intake mods: ls6 intake /2.25" cut off at rear(I know it is small)
Rear gears:4.56
Dyno HP/TQ:? I am still working on tune
Track Times and Speed:11.63 @ 117.00
w/ 4l80e (3200 circle-d stall)and 3600lb race weight
I am still working on tune , It picked up 1 tenth by lowering timing 2 deg and 1.5 mph
Still has more in it , I have the trans set to shift @6200 because it is still a fresh motor and I want to get tune set and exhaust done before I let her loose
what are you guys running for timing on pump gas ?
Old May 15, 2017 | 12:05 PM
  #108
MIKE93SVT's Avatar
[QUOTE=sjcrft19;19526543]Tick SNS Stage 2 cam Version (Regular/Mild): reg ls2
Shortblock: LQ4
Heads: 243
Ported? If yes, by who?: no
Chamber size:62
Head gasket:.LS9
Exhaust, intake mods: 1 7/8 LT, 2 1/2 dual, ported LS2 intake
Rear gears: 3.08
Dyno HP/TQ:? None yet
w/ 4L70E and FTI 4k stall
Also looking for ignition timing advice? Idle and WOT. Currently have a LS2 timing base map to drive around. But it's not optimal
Thanks
Mike
Old May 18, 2017 | 02:00 PM
  #109
BaMaDuDe87's Avatar
What has everyone experience been with the street manners with this cam? Looking to put one into a dd LS6.
Old May 18, 2017 | 06:53 PM
  #110
Mark01Ws6's Avatar
If your tuner is good. Not bad at all. It's pretty choppy. For a DD I'd go with mild lobes.
Old May 24, 2017 | 02:41 PM
  #111
Tscape16's Avatar
Very streetable with a good tune. I've only had a few issues where it won't find idle right away after driving without stopping for a while (which is most likely the tune). Otherwise, sounds great and gets down when you need it to!
Old May 25, 2017 | 10:30 AM
  #112
MIKE93SVT's Avatar
I'll second that it's all in the tune. I'm running s holley dominator and it's very smooth. Idle isn't even as choppy as the stock ecu cars I've heard. Putts around st low rpm no problem. Also helps that mine is a stalled auto
Mike
Old Dec 6, 2017 | 09:13 AM
  #113
Tick SNS Stage 2 cam Version (Regular/Mild): LS2/Regular
Heads: Stock '99 853's
Chamber size: Stock
Head gasket: Stock
Flycut? if so, how much?: No
Exhaust, intake mods: ARH 1 3/4, catted-y, Borla Adjustable CB
Rear gears: 9" with 4.10's
Dyno HP/TQ: UNK, Street/Track tuned
Track Times and Speed: 12.69@ 114, 1.99 60 ft (street tires), 12.74@115.7, 2.27 60ft (street tires)
Zero weight reduction, 2 car-seats in the back, spare tire and all still there.
Old Dec 8, 2017 | 11:33 AM
  #114
Mark01Ws6's Avatar
Get some tires and watch that et drop. I ran similar numbers on street tires too.
Old Aug 11, 2020 | 11:23 AM
  #115
Scorp38's Avatar
Bringing back from the dead.
Tick SNS Stage 2 cam Version (Regular/Mild): regular
Heads: 243 milled .010"
Chamber size: unknown
Head gasket: .051"
Flycut? if so, how much?: no
Exhaust, intake mods: 13/4 lth, 3" dual no cats. Slp lid smooth bellow.
Rear gears: 3.42
Dyno HP/TQ: 418/411
Type of dyno? (i.e. mustang dynojet): dyno jet
Track Times and Speed: none as of yet
Ran out of injector at 6200 rpm tuner says there is more in it. Its only on 22° of timing.
Old Sep 1, 2020 | 09:43 PM
  #116
themfnracetruck's Avatar
Tick SNS Stage 2 cam Version (Regular/Mild): Regular
Heads: 243s, milled .010 with fresh valve job
Ported? If yes, by who?: No
Chamber size: ~63
Head gasket: Cometic .040
Flycut? if so, how much?: Yes, .080 to be safe
Exhaust, intake mods: ported TBSS, 90mm tb, 1 3/4 headers, 3.5" single w/ cutout
Rear gears: 3.73
Dyno HP/TQ:
Type of dyno? (i.e. mustang, dynojet): none
Track Times and Speed: 12.845 @ 104.5
This is in a 99 RCSB 4WD Silverado, around 4500lb race weight w/ driver. 3600 stall. Very impressed with the driveability and power of this combo!
Old Nov 24, 2024 | 03:07 PM
  #117
Abs's Avatar
Abs
These cams used to be offered with regular and mild lobes but now I think only 1 version exists. Does anyone know which lobes they use now?
Old Nov 24, 2024 | 06:04 PM
  #118
Tuskyz28's Avatar
visit Tick website. They use cam motion cores
Old Nov 25, 2024 | 12:44 AM
  #119
Abs's Avatar
Abs
I did know that but I wonder if it's the standard cam motion lobes or their own
Old Nov 25, 2024 | 12:51 AM
  #120
Tuskyz28's Avatar
Not sure but my cam motion camshaft in my LS2 made 480 rwhp on a 48 inch drum dyno which tends to be stingy. Pump gas and hand ported 799s. Im a 100 percent sure my car makes 500 plus at the rear wheel on the 24 inch drum thats read higher vs a 48 inch drum.
