Tick SNS Torquer Stage 2 users Come On In!
This cam or a close custom from martin is my next move. Someone buy my d1sc kit... I have to sell due to tuition...
Hey Martin, you interested in a d1sc kit?
keep it coming fellas
This cam will need to be shifted at 6800-7000rpm for best performance on track and in racing situations. If you don't want to shift that high, I'd highly recommend the LS2 SNS Stage 2 231/235 .635/.610 111+2 as it only needs a 6600-6800rpm shift point for optimal performance.
Both cams will produce exceptional torque and HP curves with your 6.0, 799 headed LS6 intake combination.
Also I'm wondering what length pushrods you guys used with your sns stage 2 regular cam on regular (untouched 241 heads)
I will be buying one later this week and wanted to know.
Just put the same cam in my motor this week and when I spoke with Martin he told me 7.4 and since I already had a hardend set. That's what I went with.
It gives me hope with going with a bigger cam and keeping my stock 3.42 for now...
Heads: Stock 853
Ported? If yes, by who?:
Chamber size: Stock
Head gasket: Stock
Flycut? if so, how much? If no, what was your clearance?:
Exhaust, intake mods: 1 3/4 LT, FAST 92/90MM TB, 85 MAF, 36# Injectors
Rear gears: 3.54
Rear (i.e 9", S60, 10 bolt etc) S60
Auto or manual trans: Auto, 3600 Stall
Dyno HP/TQ: 382/370, Dynojet
Type of dyno? (i.e. mustang, dynojet):
Track Times and Speed: N\A
I am very happy with this cam, it sounds great on idle and pulls very hard. Since I am a convertible, and street manners is what I cared about most, I didn't want a cam that would require me to wind it to 6800 RPM. This setup peaks at 6300 RPM and has a nice torque curve.
As with anything when it comes to these cars, combination is key and having the proper rear gear set will really help keep the car in its power band. Especially with a 6 speed that will have a lot of RPM drop on the shift.
