Tick SNS Torquer Stage 2 users Come On In!
Old Oct 5, 2014 | 09:36 AM
  #41
poltergeist 02's Avatar
Originally Posted by laurentj23
How's this cam on dd guys?. I'm planning to put this on my build which is gonna be my dd. What mpg do you all get? And no..I don't want to drive a Honda.
It sounds like your wallet wants a Honda but you don't. If you have an M6 you shouldn't see too much of a change. If you have an auto it will suck gas around town cause of the converter.
Old Oct 5, 2014 | 10:27 AM
  #42
Rise of the Phoenix's Avatar
Keep the tune lean outside of WOT and you'll get great gas mileage.
Old Oct 5, 2014 | 03:29 PM
  #43
ls1 down under's Avatar
Originally Posted by Rise of the Phoenix
Here is a video I made today so you can hear how the cam sounds.
"The Mongoose" 2002 Trans Am WS6 - YouTube
That is an AWESOME sounding cam right there ! Such a nice chunky lope. Valve train seems quiet too.
Next build I do I'd be definitely considering the SNS stg 2 !!
Old Oct 5, 2014 | 05:49 PM
  #44
Yeah, the valve train is pretty quiet, but does have a little bit of that sewing machine noise, but that's to be expected with pretty much any cam. The Joe Gibbs LS30 oil really helps reduce the valve train noise. I will work on getting a WOT video once things quiet down some around here.
Old Oct 7, 2014 | 09:13 AM
  #45
Sales@Tick's Avatar
Originally Posted by Mark01Ws6
Ok cam update.
Cam sounds great. Initial results are in. 330 hp with converter unlocked on a stingy mustang dyno.
Long and short of it , I ran out of injectors. Was hitting 12.9 afr at 6200 and 105% duty on injectors. Looks like I need to upgrade fuel system to see full potential. Just not in budget atm so I'll have to wait and gather funds to finish it right.
All said, as it sits I think the power is about right atm. Just need to bring fuel supply up to par and I think should see another 15 to 20 in it. Probably go with about 42lb injectors.
That was in 2nd gear as well correct?
Old Oct 7, 2014 | 06:06 PM
  #46
Mark01Ws6's Avatar
Yes it was a 2nd gear pull. I suppose that would be a helpful piece of info that I should have included. :o
The curve pretty much went flat around around 5800.
Car is back at shop getting pump and injectors. No sense in having a car sitting around not finished right.
Also, wanna thank you again Martin for being so patient and helpful with advice and setup. it is greatly appreciated.
Old Oct 7, 2014 | 06:32 PM
  #47
I thought all dyno pulls are done in 4th gear???
Old Oct 8, 2014 | 07:27 AM
  #48
Mark01Ws6's Avatar
Dyno pulls are usually done in whatever gear is 1:1 ratio. 4th in a M6 and 3rd in an A4
Old Oct 9, 2014 | 09:28 AM
  #49
Sales@Tick's Avatar
No problem at all. Any thing I can help with in the future please do not be a stranger!
His tuner was worried that with the 3.23 gears making a locked pull in 3rd that the wheel speed/drum speed would be too great.
Something I've never heard anyone worrying about before with a cam only LS1, but every tuner is different.
Old Oct 10, 2014 | 07:08 PM
  #50
BlueBird346's Avatar
I haven't forgotten, here's my dyno sheet.
Old Oct 15, 2014 | 09:52 AM
  #51
Sales@Tick's Avatar
350rwtq@3000rpm is bad to the bone! 400rwtq@3750 is even better! 400rwtq for 2000rpm is impressive for the modifications and combination you have.
Very nice power curve!!!
Old Oct 22, 2014 | 01:51 PM
  #52
Mark01Ws6's Avatar
New update on cam.
In short I am totally pissed right now at the so called garage that did the work on this motor.
No dyno numbers to add to thread. Shop didn't dyno it again after injectors. The car runs but I am very displeased with the work on the car for various reasons. I apologize if the thread seemed hijacked. Just wanted to give solid information on this cam.
Old Oct 27, 2014 | 10:48 AM
  #53
Sales@Tick's Avatar
Sorry to hear about your issues sir. I hope that RPM or Frost can get you straightened out.
Old Oct 27, 2014 | 12:04 PM
  #54
Mark01Ws6's Avatar
To be fair,
the garage that did the work is trying to make good on some of the issues. I will let them have another shot at it considering I have dealt with them for many yrs and they have always done good work before.
Old Oct 27, 2014 | 12:27 PM
  #55
To be fair,
Hope you guys get it all sorted out.
Old Oct 27, 2014 | 06:44 PM
  #56
sk!nny's Avatar
Tick SNS Stage 2 cam Version (Regular/Mild): mild
Heads: tf 220
Ported? If yes, by who?: yes brian tooley
Chamber size: 64.5
Head gasket: .040
Flycut? if so, how much?: no
Exhaust, intake mods: 1 3/4 ory dumped y, fast 102/102 port matched
Rear gears: 3.43 t56
Type of dyno? (i.e. mustang, dynojet): dynapak
450hp at 6500 tuner didn't want to go higher but it was still climbing.
its my only car im in the city so it could really use some gear it likes to jerk around sometimes, once .you get to know it though and use your clutch its a lot better. it has the tsp big maf in it which I think doesn't help the off idle drivability. but overall it has 120000 miles on it so im pretty happy with it
Old Oct 29, 2014 | 03:08 PM
  #57
Sales@Tick's Avatar
The SNS Stage 2 cam and those heads have time and time again made 440-450rwhp with an awesome torque curve to boot! Very nice sir!
Old Nov 1, 2014 | 09:01 PM
  #58
Mark01Ws6's Avatar
Idle video I took a few days ago.
Old Nov 2, 2014 | 05:35 PM
  #59
silplu83's Avatar
Here is mine
Originally Posted by LS1nut346
Tick SNS Stage 2 cam Version (Regular/Mild): regular
Heads: stock 243
Ported? If yes, by who?: no
Chamber size:stock
Head gasket:stock
Flycut? if so, how much?:no
Exhaust, intake mods: LT's, y-pipe with cats, magnaflow catback fast 102
Rear gears: 4.10
Dyno HP/TQ: 399 hp 367 torque
Type of dyno? (i.e. mustang, dynojet): mustang
Track Times and Speed: none yet
Old Nov 12, 2014 | 04:31 PM
  #60
LS1nut346's Avatar
This post turned out pretty good so far. Anyone else?
