Stock LS1 Done, Decisions?
Can someone recommend best AFR Heads to go with on the stroked 5.3 build? I was looking for AFR 205's but it doesn't look like they make those any more?
Thanks
My $.02 I would keep and aluminum block for a street car and I would look in to some 317 or 243 GM heads if you are going forced induction. Use the head saving on the fuel system you'll need.
What happend to your LS1 ?
Otherwise, reuse your block, stuff some forged pistons and rods in there and let her rip if you want to turbo.
If you want to keep NA, a 5.3L bored out with a stroker kit would be nice for a 383. But the price difference between a Gen IV 402 or 416 is not much (tho you need the conversion kit which adds to the price).
Do you know what happened to your engine ? Damage ? What is your power goal with a turbo ?
I understand you completely I really do, but that's why you guys are here to ponder these questions and give input.. I know I can easily rebuild my LS1 and use the 799 heads on it, ect, ect but I was looking and upgrading now so that it may help for later.
Maybe I should just save the 5.3 block for later when the LS1 does come apart.. I dont know, I thought I had it all figured out but maybe I am over thinking it all
Here's some more info for you... Make sure you read the title.
https://ls1tech.com/forums/forced-in...lity-list.html
Here's my advice if your going to pull the engine. Hone the block to 3.903-3.905, Forged rods/piston, polish the stock crank , get a turbo cam spec'ed, new lifters and oil pump, stud the heads with a MLS gasket... Turbo that thing and let her eat 10-12 psi and have your self a 600hp street car, with room to grow.
