I keep breaking rocker arm bolts...
I bought harland sharp sls17 rockers, they were quiet and the car ran great. I started driving the car last night and it was misfiring ridiculously. Turned around, pulled the valve covers, and the harland sharp bolt had broken, but on a different cylinder.
Here's a little background information on my setup:
Texas Speed Giant cam, 248/254 duration, .615/.622 lift
LS7 lifters
Prc .700 springs
Any idea what is going on?
PRC .700" Lift Spring Specs:
Closed Spring Pressure: 160lbs @ 1.850"
Open Spring Pressure: 460lbs @ 1.150"
Maximum Spring Lift: .700"
Coil Bind 1.080"
Spring Rate: 429lbs/in
Carefully inspect the broken parts to see what isn't fitting correctly. Look for rub marks that don't belong, etc. Look at the tip of the bolt to see if it's bottoming out, and not creating the correct clamping force.
I took a few pictures for you guys to take a look at.
The YT bolt is actually a little shorter than the stock one, so I don't think it's an issue with bottoming out.
The H-S bolts say H-K 12.9 USA M8 stamped on the side.
I lost my pushrod length checking tool a year ago, and ordered a new one, and put it in my tool box only to find out it was the wrong one
Should have another here tuesday. Guy from summit is even sending me rockers after talking to him about it, which is extra nice.
With a properly preloaded bolt assembly I would think the rocker would give first, but if the bolt was free to bend back and forth even a small amount, it will break.
Also, as a point of curiosity, is this the same rocker location as the prior YT bolt failure?
used a time sert to repair it.
http://www.gtsparkplugs.com/images/Timesert_1.jpg
I'd pull off a few other rockers and inspect them carefully.
I would also be looking really closely at the pedestals. If they're allowing the rockers to move back and forth, that would be bad.
