Aluminum l98 spring height?
I took apart my aluminum l98 heads for porting a while back and now I'm ready to reassemble them. But I can't remember where all the shims go and that's stopping me. There are 16 of them all from the exhaust valves. Do I need to buy a micrometer and measure it out? I don't want to just assume that it's two each. Oh and the springs are stock.
Thanks for the patience if I typed anything real stupid sounding
Have you had a valve job done, what are the intended camshaft specs, and do you have corresponding springs to match..???
When you change the cam you have to change the springs to match the cam.
Tell us more about the whole setup, sounds like a lot of duration if this is a TPI car.
Might consider just getting the right springs, taking the heads to a shop and letting them do a valve job and the assembly.
Competition Cams 941 is one of the best and most versatile 1.26" diameter springs available. I use them all the time on stock car applications as they work for so many different setups and seem to last a long time since they are the pacalloy type wire.
A budget version is sold by Competition Products in Oshkosh, WI under the number 98215 (electro-polished).
Basically they are a great head for a 350 but so many better choices for the extra cubes.
