Rod bolts
Old Jan 4, 2015 | 04:29 PM
Dragway's Avatar
Question Rod bolts
I had my lq4 short block done new pistons bored 020 new bearings and rings I asked the machine shop about replacing my connecting rod bolts with arp's and he said they weren't needed because factory bolts looked good and I wasn't going to rev it past 6300 . Should I take it apart and put the arp bolt in ?
Old Jan 4, 2015 | 05:07 PM
KCS's Avatar
KCS
Moderator
I wouldn't.
Old Jan 4, 2015 | 08:19 PM
Taxman20's Avatar
Its a dilemma really. I would have had the shop do it in the first place no matter what their opinion was. But now that's its built, it may not be worth the effort since it isn't a real race engine. Rod bolts ALWAYS get replaced when I build an engine. Even ARP bolts because that's all I use. Rod bolts may look good, but they have been stretched already and that's where things break.
Old Jan 4, 2015 | 10:52 PM
fiveg1's Avatar
For 100 bucks I wouldn't take a chance just bite the bullet and change em
Old Jan 5, 2015 | 12:37 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Replacing the bolts in rods means re-sizing them. Stock rods can't be re-sized because they're the "cracked cap" design.
The cheapest set of Eagle rods are better than stock rods and come with ARP bolts-for $269.97 at Summit.
Carrillo rods at $294.00.
Even on a mild build, I'd ditch the stock rods.
Old Jan 5, 2015 | 07:49 AM
KCS's Avatar
KCS
Moderator
No, actually you can.
Old Jan 5, 2015 | 07:58 AM
Paul Bell's Avatar
This has been debated a few times around here and the consensus is that the replacement rod bolts from Katech are the only ones that claim can be installed in stock rods without re-sizing BUT:
https://ls1tech.com/forums/ls1tech-s...t-claimed.html
so to play it safe, bolts should not be replaced in stock rods.
Old Jan 5, 2015 | 08:53 AM
KCS's Avatar
KCS
Moderator
I was talking about resizing the rods. You can resize the cracked cap rods.
Old Jan 5, 2015 | 12:40 PM
Paul Bell's Avatar
AHH, I gotcha.
"resizing" cracked cap rods is really overboring it to use a oversize bearing.
By the time the work is done plus bolts and the bearings, it's practically the same cost as new rods.
Old Jan 5, 2015 | 12:51 PM
KCS's Avatar
KCS
Moderator
AHH, I gotcha.
It depends on the application. I don't know of any $300 set of rods with a bushed .944" pin bore and 6.100" length.
Old Jan 5, 2015 | 01:02 PM
Paul Bell's Avatar
Correct sir, those exact measurements are had in a Scat rod set at $345.00 at Summit.
Still a better rod than stock and I'd say a worthwhile purchase.
Old Jan 5, 2015 | 02:02 PM
T/A2000's Avatar
This.. not worth the effort, Better to get new rods and call it a day..
Old Jan 5, 2015 | 03:14 PM
KCS's Avatar
KCS
Moderator
Those are still a press fit, so add another $60 or so to have a machine shop hang them onto your pistons.
This is why I kept the stock bushed rods in my LS2. $100-200 here and there add up pretty quick.
Old Jan 6, 2015 | 10:53 AM
KCS's Avatar
KCS
Moderator
I've never seen a problem with the Eagle, Scat, or Compstar stuff. I always check the big end and pin end bores. Sometimes I want more clearance on the pin end, so I touch them up in the rod hone, but that's for higher power stuff.
Old Jan 6, 2015 | 11:20 AM
Taxman20's Avatar
Yea, I have been building race engines for a long time and I NEVER use Chinese stuff. I have used Scat and Eagle without any real issues. Yes, I have broken rods but that's part of racing. The rod itself wasn't the issue, normally rod bolts break or crankshaft main caps move around and throw everything off. This will happen at 8k rpm.
Old Jan 6, 2015 | 11:51 AM
KCS's Avatar
KCS
Moderator
Originally Posted by axe murderer
Guy I know that's into Oldsmobiles says BTR(Bill Trovato) doesn't like any so he buys Scat & reworks them, I guess it a preference thing.
I didn't see where he stated pressed or floating piston but Scat 26100927 are like $345 for bushed 6.1 on Jegs site (& probably a bunch of other places) which makes better sense than messing with cracked rods especially since he bored the block & should have it balanced.
That rod has a .927" pin though. I suppose you could possibly hone it out to .944", but that's more money at the machine shop.
Old Jan 6, 2015 | 01:25 PM
T/A2000's Avatar
Lol every engine builder I have talked to over the last few years, has said to stay away from eagle.
when I was planning my build I was looking at eagle kits, and everyone I talked to around town said don't do it
Everyone either recommends K1, Callies, or Scat in some instances
Old Jan 6, 2015 | 03:27 PM
Paul Bell's Avatar
I have K1 stuff in my LS1. And yes, Scat & Eagle are made from Chinese forgings.
