G5X2 and G5X3
Think of it this way....
60s Muscle car feel - G5X2
Really Really fast european car - G5X3...
the X2 just comes in hard early while the X3 doesnt really hit until 2500-2600... but pulls much harder for longer! However both of these cams will make more low end then pretty much any other cam, and I have the proof for that as many of my customers have switched from smaller "Torque cams" to the G5 cams and gained low end. Dont listen to the LG haters and just try one! you WONT regret it!
.Most people are getting the X3 on a 114. With the 112 you have to flycut the pistons, with stock unmilled heads that is.
What he said
hehe j/k His car sounds f'ing incredible and when he gets on it, it sounds like a race car, totally amazing! Mike, we need to go get some vids of our cars and sound clips so everyone knows what we are loving so much
And I got the 114 on my X3, I had a 112 on my last cam, and this 114 sounds MEANER than that 112 Comp Cams did. I can't tell the difference, and would never go back to anything else!
Im considering dropping my idle... I wanted extreme drivability, but Scotts car is identicle to mine and hes 100 rpm lower... so I might drop mine to get a lil more lope
Yeah even with the idle as it is, and I turn the A/C on it idles perfect, no surging, etc. GOD I LOVE THIS CAM! Every morning I start the car up, sit there and listen to the beautiful music, sometimes I will stand behind the car and listen to that **** rock, it's great!
j/k dude, this cam works awesome with those heads, works kick *** with stock LS1 heads like I have. X3 all the way too!
You won't regret this cam!What else do you need for a cam swap?
-springs
-retainers
-pushrods
I've heard that it's good to do the timing chain as well, yes/no? Any other information would be great, even down to the smallest nut nd bolt.
Andrew
The chain was in great shape, even with 82k miles on it, so no real need to get that. Just get new water pump and timing chain cover gaskets. Be sure to retorque the rocker arms,etc correctly. The most important thing is to MAKE SURE the cam is degreed correctly, that will kill your motor if it's off. Take your time and things will be fine.Also, be sure to COUNT all the springs, retainers and seats, etc to make sure you have all of them there, I was shorted 2 seats, so we had to make 2 temp seats from washers that were the exact size and thickness as the seats, and Lou is getting us 2 seats as we speak, he said that the temp seats will be ok in the meantime.
