Valve Spring and Cam Questions
If I run an MS3 cam in an LQ4 can I run .610 valvesprings (MS3 max lift is .609) or should the valvesprings be quite a bit higher to eliminate the risk of problems. Also how low of a stall can I run with that cam? 3500 is recommended but I've seen people run 3200. Any help is appreciated! Thanks!
Mason
Mason
http://www.jegs.com/webapp/wcs/stores/servlet/m20ProductDisplayView?pageSize=10&resultCatEntryTy pe=2&searchTerm=&catalogId=10002&langId=-1&productId=1088912&storeId=10001&sType=&pgGrp=sea rch
Alright thanks, would these also work? That's a whole kit that's a little more in my budget
Old School Heavy
http://store.cammotion.com/double-sp...teel-retainers
