Cam Advice
Old Feb 2, 2015 | 09:36 PM
JonRuh's Avatar
Default Cam Advice
I know everyone asks this but I cant make up my mind. I plan on doing a cam swap this spring but can't decide on which cam to go with. I will be doing mostly street driving and might visit the track once a year. I was thinking about going with the Torquer v2 but i'm worried that might be to much. I found the thread about the spartan cam but can't find where to buy the cam or what the lift specs are. Ive got stock 241 heads and a ls6 intake with kooks 1 7/8 headers. Anyone have any ideas on which cams would work best with this setup?
Old Feb 3, 2015 | 03:22 AM
HCI2000SS's Avatar
What trans and gearing?
Old Feb 3, 2015 | 06:30 AM
poltergeist 02's Avatar
I have always been a fan of the SteetSweeper HT (228/232 612/600 111lsa) for a street car.
Old Feb 3, 2015 | 09:26 AM
JonRuh's Avatar
m6 with 3.73 gears.
Old Feb 3, 2015 | 12:54 PM
96LT1Z's Avatar
I did ALOT of street driving with the Torquer V2. IMO it is very tame cam as for drivability. It is not bad driving on the street at all. The cam itself LOVES top end. The set up it was running it would really pull hard at the top of third gear, and all the way through fourth. Really made good power.
Old Feb 3, 2015 | 01:13 PM
JakeFusion's Avatar
Super Hulk Smash
Damian (screen name here) is the owner of Spartan Performance.
Anything in the 226-230 intake and 230-234 exhaust duration world will drive really well on the street. I'd definitely look at the 228/232 Spartan cam as it's ground on Cam Motion billet cores.
Old Feb 3, 2015 | 09:16 PM
JonRuh's Avatar
Do you happen to know the lift on the 228/232 Spartan cam?
Old Feb 3, 2015 | 09:41 PM
JakeFusion's Avatar
Super Hulk Smash
I think ~.590 ish. He probably specs them depending on your heads. Cam Motion can alter any lobe for any lift.
Old Feb 3, 2015 | 09:47 PM
HISS's Avatar
Look into the Tick Performance Saturday Night Special grinds. Martin specifically designed these for daily driving, and weekend fun while retaining good street manners.
Old Feb 9, 2015 | 02:59 PM
SJFGTO's Avatar
Check with the people who design/sell cams for a living when selecting a cam. Picking a cam by internet vote is nuts. Among the folks I'd call would be Josh at Spartan Performance. Josh will give you some recommendations for cams that are right for YOUR car, not everyone else's.
Old Feb 9, 2015 | 04:30 PM
01ssreda4's Avatar
I'm running that cam motion grind. It was originally done with 4 different lifts. Damian seemed to like the .612 lift version which is what I bought. I know cam motion will grind you whatever you want but that was just a shelf cam that is now discontinued. Out of their newest lineup the Titan4 is the closest I've found to that popular Spartan grind. Here's my junk running with it:
Old Feb 11, 2015 | 07:38 AM
01ssreda4's Avatar
Here's one on their site that is very similar....
LS2 Stage 3
Duration at .050 - 228/232
Lift with 1.7 - .603/.578
http://store.cammotion.com/60-ls2-34...-compression-3
Old Feb 11, 2015 | 12:37 PM
JonRuh's Avatar
LS2 Stage 3
Would I be able to run that in an ls1 still? Also would i be able to use single beehive springs or would I have to go up to double?
Old Feb 11, 2015 | 07:37 PM
01ssreda4's Avatar
Yes, and you could probably get away with a beehive but I'd run a dual for piece of mind.
