Ls1 vs ls6 heads
So i have heard ls1 heads ported flow the same as ls6 heads ported. I need some input. I am building a sleeper and i wanted to put ls6 heads on the car but on the ls6 head its stamped 243 on the head.
If your wanting to totally avoid possibly getting flagged on a smog check I'd have your stock heads cnc ported, and milled slightly to get the SCR up to 11:1. I believe that the LS6 heads will still have a slight potential advantage ofabout 5-10 rwhp.
Fyi, a FAST 92 intake manifold is also 50 State legal and has C.A.R.B. approval/number. So it's a good option .
Depending on how its ported yes the ls1 241 can flow better. But ls6 heads have alot more potential. They are stamped 243/799.
I wouldn't waste my time on ls1 pre 01 heads to port on .
243/799 are the best to go... 317 if your planning on boost.
I live in chicago so smog isnt a problem. And i have a 01 z28 so those heads are fine. I know the 98-00 heads suck. Also i would shave off the stamp but its a sleeper car. And i know the first thing i look at would be the heads and ppl would know right away if i shave off the stamp. And i have a money maker kit getting installed on my ls6 intake so im not going with a fast intake.
The cars gonna be setup really nice. There is alot of kids around the neighborhood with mustangs that have exhaust n they think they are hot **** at stake n shake lol. So imma beat them all pedaling obviously.
Setup:
Ported heads
Gear
Converter
Cam
Full BMR drag suspension
And my fav "The money maker kit"
Leaving stock exhaust n manifolds cause imma try n hide the cam alittle better. And if you know what the money maker kit is....well you know 😉
Setup:
Ported heads
Gear
Converter
Cam
I just finished my "sleeper" and I have to pass emissions. Originally I had a heads only car with 799 Ported heads, the 799 stamp is very hard to locate so I pass inspections. It was much better top end but hurt down low off the line with a stock cam. I thought maybe I should have done ported LS1 heads...
BUT then I put a very mild custom Tick cam in and holy cow!! what a difference!! I'm now glad I went with the LS6/LS2 heads. The car hauls and is a total sleeper, idles very close to stock and passes emissions, all on a stock stall, manifolds and cats. . The car is a blast to drive and the installer was very surprised at the performance. At an intersection you cannot tell it is not stock, total sleeper
IMO the only reason to stay with LS1 heads is cost and if you are not going to do a cam. But if a cam is ever in the future you will be glad you have the LS6 heads.
![Naughty](https://ls1tech.com/forums/images/smilies2/naughty.gif)
I just finished my "sleeper" and I have to pass emissions. Originally I had a heads only car with 799 Ported heads, the 799 stamp is very hard to locate so I pass inspections. It was much better top end but hurt down low off the line with a stock cam. I thought maybe I should have done ported LS1 heads... BUT then I put a very mild custom Tick cam in and holy cow!! what a difference!! I'm now glad I went with the LS6/LS2 heads. The car hauls and is a total sleeper, idles very close to stock and passes emissions, all on a stock stall, manifolds and cats. . The car is a blast to drive and the installer was very surprised at the performance. At an intersection you cannot tell it is not stock, total sleeper
. IMO the only reason to stay with LS1 heads is cost and if you are not going to do a cam. But if a cam is ever in the future you will be glad you have the LS6 heads.
Comes down to how much cash you have
I'm guessing that if the OP sent his factory GM castings of "whatever the **** number" to Tony Mamo, Called Martin @ Tick for the "can't hear ****" camshaft, and set his car up to hook on the street with the Money Maker:
The local Mustang kiddies are gonna feel T-Bagged....
![Moon](https://ls1tech.com/forums/images/smilies2/moon.gif)
Ton of postings about the difference between 241 & 243 heads, ports & chamber design are different & FWIW LS6 243s have light weight valves.
If you don't want people to know what castings you have get 799s & mill the visible # off, I have GM blem castings & the top 799 was removed buy the place I bought them because they're blems but is still visible from the deck side.
My 243s only have the # on top so if it's removed & you ever want to sell them guys may give you a hard time about it.
The Scammer Hammer
I'm guessing that if the OP sent his factory GM castings of "whatever the **** number" to Tony Mamo, Called Martin @ Tick for the "can't hear ****" camshaft, and set his car up to hook on the street with the Money Maker: The local Mustang kiddies are gonna feel T-Bagged....![Moon](https://ls1tech.com/forums/images/smilies2/moon.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I had to go to a "Star Certified" station. I can tell you they spend about 15 minutes under the hood with a flashlight. Not sure all they were looking at but it passed visual inspection and smog test.
Someone else I know has heads and 222/222 cam in his GTO and had to go to a Referee and passed no problems.
