caddy lifters
Old Feb 24, 2015 | 06:41 AM
cr250r's Avatar
Default caddy lifters
Has any one used these seemed like they had failures a couple years ago wondeing on budget lifters .61x/6.1x lift 224/224 6600 rpm cam
Old Feb 24, 2015 | 07:53 AM
warriorpluto's Avatar
Heard they were no good. Either get the ls7 or morel lifters. Ls7 are cheap
Old Feb 24, 2015 | 07:56 AM
MMorgan9812's Avatar
Pay the $60 more for Morel Lifters over LS7's you wont regret it
Old Feb 24, 2015 | 08:47 AM
96capricemgr's Avatar
I have used the Caddy lifters without issue, that said next set will likely be Morels
Old Feb 24, 2015 | 08:52 PM
cr250r's Avatar
Whats the rpm range on the morels?
Old Feb 25, 2015 | 01:21 AM
COSPEED2's Avatar
LS1Tech Sponsor
We have both ls7s and morel 5315s for the best price. Check out the thread here
https://ls1tech.com/forums/sponsor-group-purchases/1727033-morel-5315-ls7-lifters-cospeed-pushrods-lunati-valve-spring-kits-group-purchase-o.html
recommended rpm range is 6500 with dual springs like the lunatis in the thread with the morels. for more aggressive cam setups id def recommend the morel drop in 5315s. easy on the budget and good quality internals.
Old Feb 27, 2015 | 12:44 AM
ls1 1990 VN's Avatar
Been using the Caddi lifters for my weekend car since 2010, no issues
Old Feb 27, 2015 | 02:14 PM
COSPEED2's Avatar
LS1Tech Sponsor
For quite a bit less money you could have the proven 5315 morels. Just an observation.
Old Feb 28, 2015 | 05:22 PM
Ratical's Avatar
https://ls1tech.com/forums/sponsor-g...urchase-o.html
I sent you a PM for a set or Morel lifters.
