383 ls1
Old Mar 2, 2015 | 01:29 AM
Wheels up's Avatar
Default 383 ls1
So a buddy of mine gave me a almost complete 383 stroker. Forged pistons, Forged rods, Cam, Heads with heavy duty valve springs. All I need to get is a crank. The rod stroke?? is 6200. My question is Where can I find a steel crank for it? I am only planning on putting 450-500 to the flywheel. So for now a forged crank is not needed. I have heard that the rods are the weak point which is why I want to use the pistons, rods. I have included pictures of rods/pistons in case anyone can help. Thanks.
Old Mar 2, 2015 | 01:33 AM
Wheels up's Avatar
Pistons are made by probe and I believe rods are RPM.
Old Mar 2, 2015 | 04:39 AM
96capricemgr's Avatar
The only cast crank worth running is stock.
If you really want an aftermarket cast crank, then flip the parts and surprise your friend with a good portion of the proceeds.
Old Mar 2, 2015 | 08:22 AM
KCS's Avatar
KCS
Moderator
Callies, Lunati, Scat, and Eagle all make affordable cranks. I don't know of any 4" stroke cast cranks for the LS1, so you're going to be buying a forged crank to complete your rotating assembly.
Old Mar 2, 2015 | 09:05 AM
64post's Avatar
Attachment 490059
Attachment 490060
Attachment 490062
If your connecting rod length is 6.200" then you likely need less stroke than 4.00", Maybe 3.900 or 3.622? 4 inch stroke usually goes with 6.125" length rods. You need to research those pistons and find out what the compression/pin height is and that will tell you what stroke you'll need with those long rods…
Old Mar 2, 2015 | 11:14 PM
Wheels up's Avatar
Here is the info on the pistons. He already had the motor running with a 4.000 crank so it should be right. I am not 100% tho you guys probably know a little more than me. Any other info like Rocker recomendations, intake, head mods? anything would help me. He had this motor (383) running on almost completely stock top end.
Old Mar 2, 2015 | 11:16 PM
Wheels up's Avatar
In case you guys cant read the picture.
Bore (in):3.902 in.
Bore (mm):99.110mm
Piston Style:Flat top, with two valve reliefs
Piston Material:Forged aluminum
Compression Distance (in):1.050 in.
Piston Head Volume (cc):+3.00cc
Wrist Pin Styleress-fit or floating
Pin Diameter (in):0.927 in.
Piston Ring Thickness:1.50mm x 1.50mm x 3.00mm
Quantity:Sold as a set of 8.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
CalculatorCompression Calculator
ToolStroker Combinations
Old Mar 3, 2015 | 08:54 AM
https://ls1tech.com/forums/generation-iii-internal-engine/1773148-383-stroker-questions.html
Old Mar 3, 2015 | 02:05 PM
Know It All's Avatar
Bore (in):3.902 in.
Bore (mm):99.110mm
That compression height will work with the 6.20" rods no problem
Old Mar 3, 2015 | 05:18 PM
Wheels up's Avatar
If my friend was interested in the money he would have accepted what I offered him for the rotating assembly. I am looking to use the parts that he gave me to build a 383. Was just trying to ask for some ideas and help..
after all is that not what forums are about? There is alot of useful information in the post you linked tho thanks.
Old Mar 3, 2015 | 05:42 PM
I get that you got free parts but spending $1500 to have a stroker with unported stock heads is going to make for a turd.
To put this together well with a stroker crank balanced etc. plus complimentary topend is going to get expensive fast.
On the older smallblocks where cast chinese stroker cranks are available they are a LOT weaker than stock and fail withing your modest HP goal range.
I would either flip the parts to put towards heads and cam, or shelve them till you can spend a fair amount putting this together right. Putting free parts together halfassed, like a cast crank would be, is wasting money, not saving it.
Old Mar 3, 2015 | 05:59 PM
Wheels up's Avatar
That is exactly what I wanted to hear. Thanks for the info.
He had built it just as it is I drove it once and it seemed to have alot of
torque but in order to do it correctly if I am looking at a lot of money your right and I would be better off selling it and getting head/cam/intake combo.
Thanks for your opinion. Know anyone looking for a 383 setup? lol
Old Mar 3, 2015 | 06:47 PM
KCS's Avatar
KCS
Moderator
PM me a price.
Old Mar 5, 2015 | 09:26 PM
Wheels up's Avatar
Well for anyone still following this thread. I have decided to build the 383. My friend had a pretty good point. If I complete the forged bottom end with a new crank then I am almost sure that I will not need to modify my bottom end in the future any direction I decide to go. I am going to install ported/polished 243 heads and a ls6 intake for now along with the 383 rotating assembly and my matched valves/cam/lifters. If anyone feels like answering this feel free.
With my 4.000 crank/ 6200" rods and pistons listed above along with a 609 intake 619 exhaust at .50 cam how well do you think modified 243 heads and a ls6 intake off of a corvette would flow?
Old Mar 5, 2015 | 09:42 PM
The fact you are listing lift without mentioning duration or anything else says you don't know enough to pull this together.
