Cam Selection-stalled Auto
Old Mar 17, 2015 | 11:18 AM
NJNETSFAN's Avatar
Default Cam Selection-stalled Auto
Hey guys, looking for opinions on cam choice. Last year my car had stock 241 heads, MS3 cam, bbk intake and TB, and a 3500 stall and went 11.6 in the 1/4. I've ditched the BBK setup and went with a ported fast 90 and also picked up some 243 heads. The goal of the car is to go 10.99 this year. I'm trying to figure out which direction I should go with the Cam. I don't want to re-stall the converter so I'm thinking about going smaller on the cam to work better with the converter.
Current thoughts:
-Go with a TSP torquer V2(my old 6spd car had this cam and I liked it a lot)
-Go down as far as a 228R
-Take suggestions on more modern cams that I don't know about?
-Stay with the MS3 and see how fast I go with the new heads and intake.
Old Mar 17, 2015 | 01:33 PM
HCI2000SS's Avatar
Personally I'd stay with the MS3 cam
Old Mar 17, 2015 | 04:45 PM
Brndn59's Avatar
Stay with the ms3
Old Mar 17, 2015 | 05:17 PM
MMorgan9812's Avatar
+3
Old Mar 17, 2015 | 05:58 PM
poltergeist 02's Avatar
I vote send the converter out. You will net a better ET with a higher stall speed then you would with a cam change.
Old Mar 17, 2015 | 09:59 PM
Kingc8r's Avatar
This. Theres the SNS 2, BTR 2, Streetsweeper HT....etc. Why are you against restalling?
Old Mar 18, 2015 | 06:50 AM
NJNETSFAN's Avatar
Because I'm on a 10 bolt and the trans only has an HD-2 shiftkit in it. The current stall has gotten me consistently 1.61 60' times, so I believe it's a little looser than a 3500.
Old Mar 18, 2015 | 07:52 AM
Kingc8r's Avatar
I see. I wish I just kept my MS3 I had and optimized that setup. I switched cams and was even more disappointed. Now my car has been sitting forever because I lost a 3-4 clutch pack and I can't decide on a setup lol. Good luck.
Old Mar 18, 2015 | 08:30 AM
thunderstruck507's Avatar
Are you getting the new heads ported? Stock 243 heads will not get you where you want to go without other changes. You might see 30-35rwhp real world from the heads and ported 90mm over your current setup.
01ssreda4's Avatar
Yep, for that goal id look at changing the converter before the cam.
Old Mar 18, 2015 | 09:55 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Keep the converter and add more gear - adjust your shift points accordingly.
Old Mar 18, 2015 | 10:22 AM
Kingc8r's Avatar
It's the answer you didn't want to hear but in the end it'll be the best choice.
Old Mar 18, 2015 | 10:29 AM
If he's cutting 1.61 60ft it's going to take a fairly aggressive converter to go faster there regardless of what his is rated at. Those are 60fts in line with a Yank SS4000 based on what I've seen.
Old Mar 18, 2015 | 12:05 PM
Kingc8r's Avatar
Yea that's why I got rid of my SS3600 and went to a Circle D 4200 2E
Old Mar 18, 2015 | 01:10 PM
NJNETSFAN's Avatar
Heads will stay as cast. I may get them milled slightly, but I think 10.99 is obtainable with stock 243s. The car went 11.68 on stock heads, and the bbk intake and running 23 degrees of timing. I picked up the car last year and picked up HP tuners at the same time. I was learning along the way and the tune had improvements to be made but the season ended before I could get the tune dialed in(this is assuming that I was losing some power due to being down 4-5 degrees on timing). With an optimal tune, I think the car could have ran 11.4x with the old setup.
The car already has 3.73's and I'm crossing the line at 6k as it is(I believe a converter is probably a wise choice as I'm seeing 1k rpm of slipping on the top end when you do the backwards calculation on my trap speed and FDR).
Based on the responses, I'm thinking of going to a higher stall and just keeping the cam. I realize that is probably the easiest way to get to the goal of 10.99. I wouldn't mind making it a little more difficult by going with a more streetable cam and converter though if someone has done it in the past,which is why I started this thread.
