should I mess with these 243s?
The Scammer Hammer
I'd personally send them to AI, Livernois or the like and see what the EXPERTS say. They're pretty fubar'd. They know their porting capability and I f it comes out, it comes out.
There's no "smoothing it out" and running it. You're looking at fully porting the heads at a minimum, if not welding.
Moderator
They are from my old set up (Cammed LQ9 with 243s) I bent 2 valves and cracked its 2 guides. I was thinking about getting some used valves, new bronze guides, doing a valve job and smoothing the damage and using them in another LQ9 set up. What do you guys think? Is it worth it?
I'd say go for it.
For an example
a set of stage 3 243's are starting at $1899.99
If you send us a good set(not in need of repair)to start with they run starting at $1699.99
I think before I spent any money on those I would shop around for another set to see what you can find. It may be you can find a better starting point for no too much more than being estimated for repair of those. I would wonder if there is anything you can't see with a visual inspection.
