Want a cheap cam upgrade but keep this same sound - video
So my 243 heads and associated gaskets are in the mail and I know it would make sense that while I'm in here to do a cam swap to see the gains anyway. I just want newer technology, of the shelf, but nothing that will cause a lack of valve train reliability and I DO NOT want it to sound lumpy or too American. This is a Porsche after all. What would you guys suggest to maintain either this sound or making it sound like a Ferrari would be ok too I know that would require an x pipe and 180 degree headers but maybe there's another secret that helps a little. Hoping somebody has something cheap used? Even a stock ls6 cam?
idle
rev in parking garage
Thank you!!
idle
Thank you!!
Oh yeah I have 7.4 TPC chromoly pushrods and .625 TPC Beehive springs. There used to be a thumpr cam in the engine by the previous owner.
I will look into your suggestion. Thanks!
Your swap uses the 944 transmission right ? What clutch ?
That amuriken lope sound your trying to avoid is the sound that goes along with power. Mid-range torque and the engine coming into tune. Limiting overlap takes away that surge of power, spreads it out. You get better low rpm manners, better fuel mileage, less fuel smell at idle as a trade for the loss of power. If you plan right, maybe a few extra ponies at 7000 rpm. Less torque could mean less strain on your 944 trans and clutch.
Shorty aftermarket headers to fit within frame rails. 2.5in collectors with a y-pipe to a single 3in no cat and magnaflow muffler. I think.
Good info, thanks!
Here's a few shelf grinds I'd consider looking at. I'd also keep in mind the possibility of going with a custom cam grind.
Comp Cam 54-424-11 (212/218 115lsa+0, lift .558"/.563") which has -15* overlap and a IVC of 41.
http://www.ws6project.com/user_stor/...-lift-212-218/
Crane 1449071 (216/222 116lsa+3, .585"/.585") has -13* overlap and a IVC of 41.
http://www.ws6project.com/user_stor/...oducts_id=4924
^^^^ Something like this would be good ... and yes it cost this much to do it right with gaskets, bolt & LS2 chain.
My 221/221 115+ idles sounds similar to the video but with a deeper tone probably because of my Magnaflow.
Buy your parts a little at a time, that's what I did and in no time you'll have all your parts. Some of the parts listed are $40-$100, then the cam. After that install it and you will need a tune. Doing it correctly will leave the car reliable.
Update
Ended up going with a used SLP 51011 cam.
The specs are:
Camshaft Specs: Valve Lift Duration Duration@.050
in: .559" 267º 214º
ex: .566" 275º 222º
Centerline - 111º
Lobe Separation - 115º
Therefor: IO=23 BTDC IC=64 ABDC @ Adv
EO=77 BBDC EC=18 ATDC @ Adv
IO=-4 BTDC IC=38 ABDC @ 0.050
EO=50 BBDC EC=-8 ATDC @ 0.050
Paid $220 shipped cause I wanted it quick and didn't want to bother haggling. I am also having my head internals put into a set of take off 243s and I just purchased a dorman ls6 intake from Rockauto for $298 shipped.
Is this centerline close to the stock ls1 cam? Because that's what determines if I need to adjust valve lash right?
So I have a pretty free flowing 3 in exhaust with none of the factory emissions crap and no cat, does anyone think I might see 400 rwhp through a 5 speed?
Thanks guys! Can't wait to drive it again!
The specs are:
in: .559" 267º 214º
ex: .566" 275º 222º
Centerline - 111º
So I'm a little bummed. My cam seems to have gotten lost in the mail. And I think it would have been perfect for me. Oh, and I got the pro comp studs for a 350 sbc which I guess is different from an ls1. The right pro comp studs are $120 instead of the $50 I was thinking. So I just ended up with victor reinz tty bolts for $40.
But now back to that darn cam question. But this one is a little different. Three options:
1. https://ls1tech.com/forums/parts-cla...9-ls6-cam.html for sale here. 5308 mean z06 right?
2. 218/228 .550/.550 112lsa. Lobes similar to a cross between comp XE and XER to give you an idea on lobe ramp.
3. 226/229 .575/578 114lsa
One big point to mention here that I need the most help with: On the second and third cams I can grind in whatever LSA I want! So if I ground in like 116 or more LSA into either cam will that make any lope go away without hurting power too much? Also, of course, I will have the car tuned afterwards, so how much lopey-ness can be tuned out?
Thank you guys sooo much but I promise I am learning!
Originally Posted by TurnerJOne big point to mention here that I need the most help with: [U
On the second and third cams I can grind in whatever LSA I want![/U] So if I ground in like 116 or more LSA into either cam will that make any lope go away without hurting power too much? Also, of course, I will have the car tuned afterwards, so how much lopey-ness can be tuned out?
My 2.5* overlap cam can be made to have no chop with the right amount of timing and RPM.
I want to say Dr.Gas makes a muffler designed to make a V8 sound exotic.... might want to check into that.
