450rwhp?
Old Jul 7, 2015 | 03:12 PM
z28SSilvest's Avatar
Nice Cam + Full Exhaust + Bigger injectors + 150 shot + tune + drag radials = 500+rwhp.
Might as well run a standalone fuel system while you're saving all that head and intake manifold money.
Old Jul 8, 2015 | 12:57 AM
alfablue's Avatar
dr_whigham
were these the injectors you were talking about?
http://www.fuelairspark.com/fas/8-36...injectorshtml/
Should have a list of parts ready to go by tomorrow, have them posted up for review then.
Old Jul 8, 2015 | 08:02 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Default 450rwhp?
Originally Posted by alfablue
dr_whigham
Yes. They can be had for a 1/3 of that price though if you look around... I gave you the part #...
Old Jul 8, 2015 | 11:52 AM
alfablue's Avatar
oh **** you did haha. My bad. I'll take a look around and see what I can find.
Anyway, here's what I've got:
Clevite bearings
Scat 6.125 rods
Wiseco pistons
ARH 205 heads (gonna get them milled to about 11.2 cr)
btr platinum springs
fast 92/92
still need to talk to Tony Mamo about a cam
stock rockers w/ trunion
ported ls6 pump
Monster stg 2 single disc
anything else?
Old Jul 8, 2015 | 12:35 PM
blueracer15's Avatar
check these out
http://granatellimotorsports.com/ind...parent=24&pg=1
im looking to add these just a wire upgrade gives 15whp
Old Jul 8, 2015 | 01:42 PM
alfablue's Avatar
Originally Posted by blueracer15
check these out
Where did you get the idea that upgrading your spark plug wires will give you 15 whp?
Old Jul 8, 2015 | 02:03 PM
TyCZ28's Avatar
Seen the MS4, Fast 92/92 and 2.5 5. heads do more than 450rwhp numerous times
Old Jul 8, 2015 | 03:54 PM
dr_whigham's Avatar
The Scammer Hammer
Default 450rwhp?
I personally wouldn't want to DD an MS4. I'm not saying you can't by any means, but you can hit that goal with a LOT less stick.
Old Jul 8, 2015 | 04:47 PM
TyCZ28's Avatar
Im a firm believer that drivability is all in the tune.. A poor tuner can make a baby cam drive bad and a good tuner can make a monster cam drive smooth. My cam is a quite large cam and drives super smooth.
Old Jul 8, 2015 | 04:55 PM
HCI2000SS's Avatar
I have a cam thats between a MS3 & MS4 with PRC 5.3 heads and a Fast 92 on a 6.0. I can't imagine I'm any more than 450 rwhp to be honest, but it does run strong. Even with this combo I wouldn't want a cam that was much bigger when it comes to general drivability
Old Jul 8, 2015 | 05:03 PM
Darth_V8r's Avatar
Moderator
^^^^There is truth to that. I cringe when I see people pick a cam for sound. That can be tuned. You can cut the idle speed and timing on a stock cam to get it to shake the car if you want. A bigger cam can be tamed.
That said, I also tend to think some of these cars are over-cammed. You reach a point of diminishing returns. And eventually, you reach a tipping point where if you can't take advantage of the larger cam (rpms, supporting mods) you actually lose power where you need it. Like my cam, I would consider a medium cam - 227/236. I could throw in a larger cam to get maybe 10-15 more HP, or I could replace the budget ported heads with heads that have far better low lift flow and take better advantage of the cam.
DR's point is very valid - you don't NEED the MS4 or similar to hit 450. Of course it'll do it, but you can do it on a milder cam with a broader torque curve. And he stated that with his driving preference. Some people love driving the polluter, which is a pretty big cam.
The most important factor is how the OP wants it to drive and act.
Reply meant for TyCZ28
Old Jul 8, 2015 | 05:27 PM
  #32
TyCZ28's Avatar
And i agree with that. id consider the T-Rex, Polluter and MS4 a max effort cam were as the Torquer 2 and 4 and say most cams in the 230's range id consider a medium cam.
Alot of people would be just fine with the 228R but not every 228r cam out there is pushing 450+rwhp
Example of 2 cars ive built recently
2002ss 1 3/4 headers light ported ls6 heads ls6 intake 228/234 cam made 400/390
2000 T/A 1 7/8 headers 2.6 ls6 heads ls6 intake MS4 made 460/420
Old Jul 8, 2015 | 06:43 PM
  #33
mac62989's Avatar
I always liked this affordable combo
https://ls1tech.com/forums/dynamomet...o-results.html
Old Jul 9, 2015 | 08:33 PM
  #34
elephantrider's Avatar
those are the heads i run ( no milling ), along with the ms3 cam,
and its very driveable. i do have a m6, so that certainly helps,
but its ALL in the tune, for sure.
Old Jul 9, 2015 | 10:10 PM
  #35
2000 cam'n SS's Avatar
I made 459 to the tire with the timing backed down for a 200 hit. N/A through a th 400 and 12 bolt with ls1 cathedral port heads MTI reworked them and a vindicator cam shaft. Both of witch are for sale.
Old Jul 9, 2015 | 10:11 PM
  #36
Ls1 383 motor
Old Jul 10, 2015 | 06:55 PM
  #37
alfablue's Avatar
Since it seems so easy to reach 450rwhp, in keeping with Tony Mamo's 'Do it once, do it right', has anyone gone to 500+ and kept driveability with stock displacement?
Old Jul 10, 2015 | 07:16 PM
  #38
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Has been done a few times in the past.
5.7 expensive with allot of attention to details including light clutch
And wheels/tires.
6.0 easier.
6.2 much easier.
Heads are better, Intake Manifolds are better/bigger, cams,springs,lifters,
are better. Still an expensive proposition with 5.7, M6 ~20 horses easier
Then autos.
What are you starting with and what is your goal/application?
Also search is your friend!
There is a very long thread about "RECIPE for 500RWHP"
Old Jul 10, 2015 | 08:14 PM
  #39
alfablue's Avatar
Yeah sorry, I found that thread almost immediately after I made this post lol.
Considering the amount of work involved and my budget, I figure I'll just stay with my goal of 450.
At the moment, aside from a catback and an SLP lid, my car is bone stock.
Old Jul 11, 2015 | 12:26 AM
  #40
alfablue's Avatar
Also, this is probably a silly question (and the wrong forum, I'll put up a topic there if necessary) but I'm planning my bolt-ons at the same time.
I was planning on a set of pacesetter 1-7/8"s with either TSPs y-pipe, or a custom one with a flowmaster merge. At this much hp, am I going to see any kind of restriction sticking with the single pipe setup? (Catback is a Magnaflow, btw)
