limits of ls7 lifters
When aggressive lobe camshafts with higher spring rates are used, then it's time to jump up to a 2110 Johnson for a quality drop in or 2116 for a reduced travel link bar.
Have folks ran LS7 lifters with aggressive cams and big valve springs...yes. Is it the right way to do things, I will let somebody else answer that because opinions are like ********.
To the OP, we use LS7 lifters in most of our builds with great success. The only time we are forced to use a different lifter is if someone is using a GM LSX block or they are pushing higher rpms than 7,000. Then we choose to go to the link bar style lifters. We also offer Morel lifters which many really like as well. When customer's are pushing over 1,000 rwhp I will usually recommend the Morel link bar lifters. They are a little more expensive but we have had great results with the morel's. Give us a call. We would be happy to go over your combination and help point you in the right direction.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
And I'm pretty sure lifters used in 60k Z06s are a bit better than ones in fbodies.
We have used them in many high hp builds.
Now what is different is the cycle life on the part With heavier spring pressures and more rpm these are not 100,000 mile parts.
We recommend halving the o.e. cycle life, same goes for the o.e. rockers.
When the valve train is set up properly we have had great durability out of those.
Thus having a turbo car that you rev to 6000rpm means LS7s are just fine. Expensive linkbars are for sustained and high RPM, not necessarily power.
Although I would still do something a little more than the LS7s, there's no need for 1000 dollar set of lifters. Leave that for the people looking to turn 8000rpm on a consistent basis.
