Flat top pistons with high lift cam
So I am rebuilding this 5.3 and have a set of engine tech flat top pistons I wanted to run.
Will the the valves be ok with the cam I am running? Block is at the machine shop getting .50mm bore/20 over bore. Should put me just over 10:1 cr I am thinking?
CAM SPECS
COMP Cams#249-54-455-11
LS1 Camshaft
Hyd. Roller
1300-6500rpm
Adv. Dur. 265 Int./273 Exh.
Valve Lift .604 Int./.610 Exh.
Lobe Angle 112 deg.
CAM SPECS
LS1 Camshaft
Hyd. Roller
1300-6500rpm
Lobe Angle 112 deg.
Moderator
CAM SPECS
LS1 Camshaft
Hyd. Roller
1300-6500rpm
Lobe Angle 112 deg.
CAM SPECS
LS1 Camshaft
Hyd. Roller
1300-6500rpm
Lobe Angle 112 deg.
would you guys recommend me going with a thicker head gasket to play it safe? If so, how thick? thanks for the help as I need it, this is my first LS based motor build, so I am learning.
You are quoting duration in advertised numbers and now want to consider screwing up quench and compression for PTV clearance. That much lift on that short a duration is going to be likely hard on springs.
I would settle down, do more research, don't trust catalog companies or Comp for advise which is I would guess how you chose that cam.
Moderator
Received 1,838 Likes
I recommend talking with kip at cam motion. Plus you get a cam dr report with the cam so you know what you got. He will get you a cam that will make plenty of power and easier on the valve train.
Also, keep in mind duration, not lift, causes PTV issues. By the time you get to 600, the piston is halfway down the bore.
Moderator
