Rod bolts
I only use ARP when building new or rebuilding engines and have never had an issue. This includes engines making over 1200hp NA.
But if using torque there would be zero difference that the rod cap will see.
Also, "torque is torque" is not really true. There are other variables that will make two bolts torqued to the same value have different clamping loads.
Yes, there can be very small differences when using torque methods. The threads not being perfect, the lube used on the threads ect, ect. But I feel its a better way to set anything up. Hasn't done me wrong yet.
car, stock rotating assm. ls6 intake and headers.
I have read where people take 1 bolt out at a time, torque that new one in, then do the
other, personally I don't have much faith in that method, but that is just me, I'm the
guy that pulls an engine out to fix a oil leak, if it's not a real simple fix in the vehicle.
My .02
Just what is the point of ARP bolts if you only tighten them to the same torque as the stock bolts?
The matter of using ARP vs. Stock bolts is the tensile strength of the bolt. It has nothing to do with torque. ARP is stronger than stock, period. They have less failure rates, period. I have broken more than my share of rod bolts and 99% of the were stock due to building budget minded stock car engines. About 400 to 450hp with a 2bbl carb. When you build NA engines making 1200+hp and then spray another 7-900 to it as we ran in our drag cars, you don't take chances with stock parts. Any stock parts. Build a stock or lower HP engine then sure, anything can work.
We will agree to disagree on this topic.
And torque is torque. You don't use the same bolt stretch measurements as GM with ARP anyway.
Also, the GM bolts ARE the weak link in the bottom of these motors anyway when it comes to making power. Why risk it?
As for the torque to angle, the thought process is: as the torque load increases, frictional variables increase. These frictional variables can cause a torque wrench to read fully torqued when it has not yet reached its optimal stretch. in the field these variables can be a problem.
In the case of a rod bolt, there is a process that I think is superior to both torque specs and TTA, that is rod bolt stretch. Professional engine builders use a combination of torque specs and rod bolt stretch measured with a special micrometer to assure the bolt has and will maintain its proper clamping force in all conditions.
In general, the aftermarket bolts like the ARP will have a higher clamping load. This additional clamping load can and does distort the bore concentricity.
If you want to do it right, install the rod bolts with the above method then check the rod bore for size and roundness and resize the rods as needed. This is how the pros do it for a reason.
Speedtiger. I wouldn't be trying to under-torque at all. I do not feel that it causes any bore issues with the rods when using ARP bolts. That was the first OP question.
I have had engines built by torque and stretch. Both work fine with neither one seeming to be any stronger or reliable than the other. Both have failures. My point is simple. First we torqued bolts. Then the better option was to use stretch. Now the better option is to use angle. And in reality the torque version we used for 100 years worked just fine. I do not see any data that verifies that the next 2 types were any better. And I mean real world data, meaning I use it myself or have first hand knowledge. Its the job of the designers and engineers to make it look better or it would never sell.
And just like you, you believe that the stretch method is better than the other 2, even though GM swears on the bible that the TTA method is better because they spent millions to engineer and prove it. I feel torque is better.
I had a Reher-Morrison 565ci 1000hp NA engine in my dragster. Each year it was freshened up. I could spend 3-6000.00 on the rebuild to be done by Reher-Morrison depending on the parts needed, which used the stretch method. Or I can spend 1000.00 or less and do it myself using the torque method. I had no higher failure rate either way. I actually never had the engine fail. So neither method was proven better. It just proved to me that my way with using torque is just as good as the new ways.
I guess I am still sort of old school. They just haven't proven anything to me personally. I'll continue to make sure the threads are all clean, use the right lubricant, ARP bolts, a quality torque wrench and go to town.
On this first LS based build, I will test the angle method. That was already the plan. But I am also going to check what the torque is on every bolt.
The caps are designed to have a specific pressure applied to them. The cap only sees that pressure. It has no idea of the hardness or softness of the bolt that installed in it. 100lbs is 100lbs no matter the bolt used. The cap couldn't care less what bolt is used.
My other point was that ARP is stronger than stock. That's all. Then this whole torque thing popped up.
But that's where I like torque method better than angle. Doesn't matter what bolt is used. And this is how I am making a statement. Using torque, not angle.
The angle method takes the friction out of the equation. Seems the better method to me.
Try this, put one bolt in dry, one lubed with this fancy wrench and see what the torque difference is.
As far as every bolt being exactly the same, I'd bet they are pretty damn consistent.
I reused the stock bolts and bearings in my SBE turbo car as many folks do. If it was all messed up due to bearings out of round and weakened bolts etc, it would have died long ago. Yet it's survived at 800+ WHP and 7200 rpm for 80 passes now.
I'll be taking it apart for upgrades and more hp for next year. I'll see how it all looks.
Ron
Ron
