Milling 706 Heads 228r 5.3
Hey guys, I have an 04 LM7 5.3 with 706 heads. They are not castech heads, so I am having them worked over, and I was wondering with a 228r cam, how much can I safely mill with PTV clearance issues. .030? Ideally id like to run stock head gaskets.
The motor is in a 2wd S10, not a Daily driver, Texas Speed recommended a 112 LSA. Heads are going to our engine builder for a full port and polish. I purchased the PRC double spring kit.
Moderator
Received 1,838 Likes
I think that can will do ok in a S10. If it were a heavier vehicle, it would be a problem. What rear gear will you run? You will probably want a 3.73 or 4.11 with that set up
