When changing head gaskets....
Old Jan 12, 2016 | 05:08 PM
b0b's Avatar
b0b
Default When changing head gaskets....
Switching from a cometic mls to GM mls. H/C LS1 will have 100-150 nitrous plate. Is it a good/bad idea to use the permatex copper gasket sealant spray?
Old Jan 13, 2016 | 01:08 PM
.boB's Avatar
They are designed to go on dry, as supplied.
Old Jan 13, 2016 | 01:37 PM
00SlvrSS's Avatar
Dry. Nothing else.
Old Jan 13, 2016 | 01:39 PM
gsxrdan2's Avatar
I just performed the same install,I tried them dry with studs.I'll lyk how well it works in a couple months.
Old Jan 13, 2016 | 01:41 PM
Marc 85Z28's Avatar
All MLS gaskets are designed to go on dry. They're also designed to be used with a proper sealing surface, which most don't have unless both the head and block were finished at a machine shop. For that reason, use the spray.
Old Jan 13, 2016 | 02:29 PM
b0b's Avatar
b0b
Ok so we can agree they are "designed to go on dry". If you have two surfaces that aren't freshly machined is it going to "hurt" to use is at extra insurance. I'm doing this because I'm pushing water on WOT and have tried EVERYTHING else but head gaskets. Don't want to do this and still have the same problem.
Old Jan 13, 2016 | 03:27 PM
Darth_V8r's Avatar
Moderator
I've used copper spray on my last two MLS head gasket sets. I agree with above post. Shouldn't be necessary, but in the garage with less than ideal surface finishes, the copper spray is cheap insurance. No harm in using it. No leaks on either of mine.
Old Jan 13, 2016 | 05:02 PM
Majestic9C1's Avatar
better to have it and not need it then to need it and not have it.
Old Jan 13, 2016 | 05:45 PM
b0b's Avatar
b0b
Thank you very much. You think it will be ok with nitrous?
Old Jan 13, 2016 | 05:50 PM
Darth_V8r's Avatar
Moderator
I honestly think so but I have never used nitrous. I can't imagine why it would be harmful with nitrous.
