Cam Install on LS6
Is this info true, and if so, how hard is it to dail in a cam?
Thanks
D.
It sounds like your friend doesn't want you to make your car any faster.
. And I guess that is the difference between installers
vs. professional engine builders
.Yes, most do get away with "shade tree machanic" type dot to dot cam install, but will never know how much HP they left on the table by it be off, if it was
.Also, be careful, just cause you take your LS1 to a good speed shop doesn't mean they always degree a cam in.....I had to pay $50 extra to my cam install for this. You will also need an adj. timing chain otherwise there will be no way to make the slight corrections with the factory chain.
On a second note, comp cams seems to line up dot to dot more accurately than Lunaty(sp?).
.The Best V8 Stories One Small Block at Time
The power isn't lost, it's just in the wrong place (rpm).
daniel
