Stuck on my 5.3 Boost bolt-on Build
I picked up a 02/LM7 Iron block 862 Head 5.3 with 68,000 original miles, everything has gone well so far.
-Decked and cleaned the heads
-Lapped the valves
-ARP Head Studs
-LJMS S2 Turbo Cam
-PAC springs/retainers
-7.400 Pushrods hardened
-LS9 Headgaskets
So I was getting ready to assemble the heads when a little birdy in my ear recommended that I open up the top ring gap from .024 to .028 since this motor is going to see a lot of boost on an S480. Since I had a little issue with some of my old rusted feeler gauges the first top ring got opened up to more like .034" which leads me to my dilemma.
1. Just run it with that .034" gap and make sure the others are .028"?
2. Just run it with that .034" gap and bring all the other top rings up to .034"?
3. Get another stock ring from a buddy off a used motor and gap that ring to .028" but not worry about poor sealing since its a used ring on an un-honed motor?
4. Pull everything, hone the motor, and get new rings on the factory cast pistons? If so what PN or link for the rings I need?
Thanks guys for the help!
Is that so? lol Its actually a very easy swap, Im using Holley Dominator for the wiring along with their dash so the electrical is easy. As for the motor mounts there are several companies that make conversion mounts. Besides the electrical, motor mounts, only other stuff that needs to be done is electric power steering rack gets moved 4" forward (adapter plates available to buy), a cross bar in the bay gets cut out, and there is a sway bar relocation if you want to run one. Besides that there is no cutting involved and everything fits perfectly.
I have different mounts but this gives you an idea of what you need to do the swap if youre curious. http://www.importmuscle.com/
Ive got everything to assemble the 5.3 just not sure what to do now that I gapped one of the top rings up too large. Ugh.
Non-Sponsor Soliciting Policy
BTW I have always wanted to do a turbo LS S2000! I love anything thats an import car thats turbo LS swapped. Best swaps hands down in my opinion...hence my turbo LS 300zx I built.
I've been running the hell out of it for a year with no issues. I don't even have anything hooked up for PCV, just open vents, and I get 0 blow by.
Just to confirm for a max effort stock block turbo 5.3 build what ring gaps do I want?
top ring .028"?
second ring .024"?
oil rings ??
