If you haven't tought much about the oil galley Barbell check this out!
#85
Thank you for your business and kind words!
Christian
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#87
Thanks Corey for your business and the kind word and photo!
Christian
Christian
__________________
#88
We keep all of our Billet Oil System Improvement parts in stock for when you're ready to keep unfiltered oil out of your bearings and lifters.
http://www.saccitycorvette.com/OilSy...provement.html
Thank you!
Christian
Thank you!
Christian
__________________
#90
Just added!
Thank you,
Christian
__________________
#91
If you have your Rear Main Seal Cover off, you have easy a access to your barbell. This is a inexpensive worthwhile product that keeps unfiltered oil out of your bearing and lifters.
LS and LT1 lifters have tiny needle bearing in the rollers, small particles getting in these bearing greatly reduces there life especially with cam swaps that use heavier valve spring pressures that apply more pressure to these bearings.
Top engine builders like Texas Speed and WS6 Store use our barbells in there engine builds.
Thank you
Christian
Thank you
Christian
__________________
#94
The factory barbell is plastic. The bevel is not really necessary for it to function as it is supposed to.
#95
Hi Tramminc,
The packaging you are showing tells me it was purchased quit while ago, like in 2017. It is identical to the updated ones except for the taper.
Here is how we have been packaging them for almost 2 yrs even before the taper.
Thank you,
Christian
Thank you,
Christian
__________________
#96
You need to take another look at what the Barbell does. Even the biggest LS engine builders like Texas Speed use our barbells in their builds because they know the OIL DIVERTER (barbell) is supposed to "divert" the oil
down through the filter! Any oil that gets by the barbell is not filtered! GM is ok with a certain amount of unfiltered oil going through the engine but we aren't.
Thanks
Christian
__________________
#97
Hi DietCoke,
Thanks
Christian
Thanks
Christian
#98
LS1Tech Premium Sponsor
Getting rid of 1 way guarantees more oil will get filtered. Plus artificial pressure loss.
Thats not a bad thing. The other pressure bypass works differently. Its not always on like the barbell is.
Ive pulled apart so many ls engines that had issues and the barbell rows had pieces of trash and bearing material stuck in them you can only imagine what doesnt get caught. Its a constant "leak" also
#99
WS6Store gets it and they do a lot of LS engine builds using our Barbells!
Thanks
Christian
__________________
#100
Thank you everyone for all your business!
Our Billet Oil Improvement Parts are in stock ready for same day shipping!
Christian
Christian
__________________
