Oil pressure problems. Any advice?
Now when throttle is applied driving around town it goes up to about 40psi but anything over half throttle or even at WOT it drops to about 10psi. At that time I left off completely and it goes back to 40psi. Hit it again and it drops to 10psi.
My friend said to change the opsu so I will do that first. But I'm fearing it may be the pump or a bearing. Any suggestions?
I'm thinking of changing the opsu first and take the intake off to see how much oil is passing through the intake and heads. Then I'll drain the oil and cut the filter. I didn't see any glitter from the dipstick but I'll be checking when I cut the filter.
Hoping it's nothing serious but I wanted to see if anyone encountered this.
Thanks!
It's not uncommon for oil pressure to drop once you get some heat into the engine ( My truck does the same thing) but should not to lose pressure under throttle. My truck will also show better pressure for the first 1000 miles after an oil change then slowly lose pressure as the oil ages.
You might try adding an extra quart of oil to see if it helps the dropping pressure under throttle.
Well, I don't know when the pump was changed, if ever. Might as well do a cam while I'm in there. Oil is dark as coal. This all started after I changed the oil. Guess the previous owner was running thicker, conventional oil maybe. Switched to Mobil 1 5w30 this oil changed and pressure went wacky and oils is coal black. Going to drain and cut the filter to check for glitter and try and source an lq4/9 or lm7 shortblock at the same time.
I've been doing this to mine for the last 50k but I think its time to change because its just too far gone. If you would see the factory oring you would understand why it needs changing. It wasn't made for this type of service in dirty acidy used engine oil. The new replacement orings are..........
