224r vs 228r
224r vs 228r
Needing help deciding between either of the two cams at 114 LSA, .600 lift. My current setup is an 03 RCSB Sierra LQ4 with a few bolt-ons. I'm for sure wanting to go one of these routes and plan on milling the stock 317 heads by .030 while I'm at it. I want to be able to get it out and drive it anytime I like. I do plan on a shift kit, and Stall sometime in the near future, probably somewhere around 3200. I've heard and been told that the 224r would be best just from a few people, but it seems that I'd have better luck out of a 228r with that kind of stall. Any reccomendations welcome. Thanks.
LS1Tech Premium Sponsor
The 224R cam will work on a stock stall. The 228R cam would need a stall converter so the vehicle doesn't try to push through the brakes. The best performer would be the 228R cam and your 3200 stall choice.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Lonnie
__________________
I've always had luck with high compression/smallish cam combos for street motors. In my opinion they are the funnest to drive. I would do a 224r in that truck even with the stall. It will deal with the weight better than a 228.
Per TSP's website, "The 228R camshaft is a very popular camshaft for customers wanting a very streetable camshaft that makes approximately 5-7 more horsepower than the 224R camshaft."
I would want the 224R for a truck with a 6.0 for the reasons already listed, 5-7hp isn't much difference between them.
I've got this combination in a RCSB Silverado and have been quite happy with it. 6.0 LQ4 with the 228R and a 3200 stall FTI converter. It's been fine on the street, but really puts a smile on your face when you step down on it.
