LS1 loses compression and misses once driven
If it checks out mechanically, Then look into Fuel and spark.
What was the fuel pressure?
Only other thing would be if the reluctor split or moved.
If everything checks out, Then You may need to de-sensitize the settings in the tune.
I am not a tuner, but I have heard this sometimes is required with an aftermarket cam.
I would verify everything checks out 100% before doing it though.
When the miss happens, the only thing that changes is the compression on that one cylinder. Once it starts to miss, it will run on 7 cylinders until you let it cool down for awhile. Start it up later, runs on 8 until you get heavy on the throttle then dead misses for as long as you want to drive it.
And then when it cools down you can start it and it runs ok until the misfire happens again...?
This does sound like lifters sticking, as you alluded to above.
What does your oil look like (does it have air bubbles in it, or anything else)...?
+1 check crank thrust/endplay.
I'm wondering if cam is walking (or trying to), check the retainer plate for wear.
Rockinws6- It did it before with yellow springs and it continued with the new PAC 1218s I put in. All valves seemed to go in smoothly with minimal drag. I didn't notice a loose seat but I can pull the valve and check.
I had one that would shut off in traffic when you come to a stop. Then it would restart and run perfect. ALL the lifters were bad, pumping up and holding the valves open. 3 other wrenches looked at it before I did and changed all kinds of things without fixing it. You can see its not always easy to diagnose a problem. You may need to seek out a very experienced wrench. Good Luck
