LQ4 Rebuild Plan and Questions
Bought an LQ4 that the seller claims "ran when pulled". Whatever, I know better. I tore it apart.
My plan for rebuild is the following (attempting to keep budget reasonable):
- Clean block and crank. Crank inspection, possibly polish. Cylinder bores look great - only planning on a flex hone.
- Clean and reuse piston assemblies. Any recommendations on best way to clean these?
- Replace main and rod bearings with Clevite H Series. Line hone - necessary?
- Reuse main cap bolts. These are torque to angle not TTY.
- ARP cracked rod bolts
- HEADS: 243 heads shaved to 61cc chambers. Ported .600 PAC 1218. COMP trunion upgrade. Stock rockers. Stock lifters. LS2 trays. Brian Tooley push rods. ARP Head bolts.
- Cam: Id like a mild to medium cam (future plan is to purchase some unshaven 243s to brind SCR back down to boost) that would work well with boost in a couple of years after the motor is broken in. Plan is to have Brian Tooley spec the cam. Not wanting to fly cut pistons if I dont have to.
- Truck intake. Maybe upgrade to gen4 with 92mm TB (still trying to keep the budget in check).
- Other non major items: LS2 timing chain upgrade. GM Muscle Car oil pan. D585 coils. Melling 10296 Oil Pump. 8.1 injectors (I understand stock LQ4 injectors are near their limit)
Looking forward to your thoughts and justifications on this build. Using LS1tech and Potaks book for references.
Rpmspeedtech@gmail.com
Thanks!!
I'll upgrade pushrods both times. With this motor and the final heads. I would just build this car boosted now but my thought process is boosting a looser motor is better. So I think breaking this build in is a better way to go about it. Plus, I already have the shaved heads from a previous build.
What about flex plate? Factory ok?
Also, lesser known but quality torque converters for 4L80E?
Seriously email us, we can get you set up with everything you need.
A high quality 4l80 stall will run about $800+
What stall speed do you think I should look at for a 3300lb car and 3.55 rear gear? Im not drag racing. Want this car to be a nice touring car.
Now, without replacing pistons and rods to a forged set up using 6.125" rods, it appears as if my options are limited to hypereutectic for direct replacements.
I wasnt planning on dropping an extra $1000 on this build. Are there any piston options out there that allow me to reuse the stock rods?
If you want more info, like i said shoot me an email.
