Head gasket diagnosis help
It idles with a slight miss but really not that bad. My scanner isn't picking up any misfires. A compression test shows even compression. When it is cold it will warm up without putting any air into the surge tank. If I just fire it up cold and drive it to work which is about 5 miles it will push 2 gallons of water out of the system. If I fire it up and let it warm up then drive the same distance it goes through less than half a gallon. I know that it could be the metal expanding to make it seal somewhat better but it doesn't seem like a gallon and a half difference would be possible with metal expansion. The thermostat is opening and closing properly. I did notice that the steam vent line to the radiator doesn't seem to be as warm as the radiator hoses and lines to the surge tank. The oil is fine, it is not milkshake.
I really feel like I am missing something here even though I was solid in my diagnosis initially when seeing the air in the surge tank.
Do a cooling system pressure test. Rent the tool and the cap adapter from your local auto parts store
The silverado/tahoe/suburban are known to have leaks at the heater hose connectors at the firewall
The cooling system MUST hold pressure OR the coolant WILL BOIL.
When the other items are repaired/correct, YES do a "leak down" if it overheats.
I do not trust those "repair shops" for good tech.
Lance
Replace the radiator
I was bored when I got home and I air checked the cylinders with 130-140 psi. No bubbles. Then I did a compression check, 160-170 in all 8. The new radiator won't be here until Friday, possibly Monday. I will update as I have more info.
Also starting to sound like you may not have a blown headgasket if you pressurized the system and saw no bubbles, but things change when it's hot and under combustion pressure so hopefully you get lucky.
I found Hyper Lube Coolant Treatment for $12.00 at Car Quest. (1/2 that of a gallon of Antifreeze Coolant)
This product will ADD the required chemicals to make the Distilled Water stable.
I also used one gallon of normal coolant mixed with "soft" water.
I believe it is normal for a slight "rough run" at start up, not a coolant leak.
Lance, BTW I place a magnet inside the Oil Filter.
